21 hours ago, MaLd0n said:
Use adblocker ever in media fire. i put warning there some time ago :)
Where do you get an adblocker for a Mac?
A legitimate site will have the link plus all the ad links. The link provided has no link to any files at all.
The version I'm trying to get working is for Beta 2.
Also, I am working with Bios version 2002. The 3000 version broke the install completely, so I went back.
adguard, google chrome extension
I do not understand when i get to here @MaLd0n
3- Check disks with diskutil list in terminal
***Pay attention, you need restore partition that has EFI partition and 120gb, check image below***
-Run in terminal-
diskutil list
In my case .dmg mounted is disk5 and my NVME is disk1
*mounted .dmg have 120 gb*
If i running macOS Catalina already with Clover! and i want Big Sur. Won't doing this for these steps erase the EFI partition in your macOS messing it up? Please be clear I want Big Sur but clean install
have many partitions, u just need check correct
3 minutes ago, batmanm0b1e said:
explain?
u need restore a 120gb partition with EFI
I already have macOS Catalina installed? How do i install Big Sur? won't it mess up the install of Catalina..!!! i do not understand.
On 7/22/2020 at 10:56 AM, d5aqoep said:
You can try my Clover 5120 EFI which is MSI X299 Tomahawk AC. Just make sure you are using the latest bios.
https://www104.zippyshare.com/v/XqkFUqaR/file.html
You may have to change the uia_exclude=HS01,HS02 entry under Boot arguments to disable your unneeded USB ports. Figure that out using Hackintool. I don't use HS01 and HS02 ports. Delete them if you want.
Edit: New link of my EFI because this one is the correct one.
Okay. I was able to download your EFI.
It is getting further, but still getting stuck. I tried changing the config file, using different drivers, or kexts, different Mac models, nothing helped.
It's now stopping at IOUSBHost Interface.
This Asus Prime A X299 is different than other motherboards. The EVGA X299 Micro was much easier to get working with 10.13, 10.14 and 10.15. I tried updating the bios to 3006 and it brick walled all the systems, as it couldn't even load the clover boot loader. I might try it with this new version and see what happens.
If I may ask, where did you find the EFI you're using?
IMG_9091.JPG.zip
9 hours ago, MaLd0n said:
this efi stay work for me via usb boot xD
Did the update with the stock OC pre-made Efi and it works, no usb just from system pref pane and then when it all loaded I put my refi folder back, restarted and beta 3 is working. I see that Apple fixed the bug in time settings and it seems so much faster and smoother as well.
Gigabyte Z490 Vision D
i7-11700K RocketLake
Powercolour RX6800XT
MacOS Big Sur
Monterey
hello ! thanks for your fantastic job..But , most of guides are for laptop.. and I have this desktop:
ASUS G11-CD
i5 / 7400
Mob:  H110-M. RAM : 8 GB
(GC: nvidia 1050 no works)
1/. Catalina  works perfectly in my SSDs external or internal..
BigSur beta3 works only on external drive AND OpenCore...
Impossible to access to my BigSur when I connect my external SSD in internal...
Impossible to install ( from Olarila image of BigSur..) on internal HDD/SDD , because when I am on the first window  , disk utility don't show any internal drive !! ??
2/ If BS works on external , it's only by booting from OPENCORE , I spend days to create a EFI with CLOVER ( following all your guides...) ..!! I follow your guide  but nothing works....may be some drivers are missed or wrong , may be some kexts are too old or for OC .. Could you help me ?? THANKS
(posted EFI folder )
BIOS.zip configLASTOFLAST.plist.zip UEFI.zip Other copy.zip
ASUS G11-CD
i5 / 7400
BIOS.zip 49.64 kB · 1 download configLASTOFLAST.plist.zip 2.52 kB · 2 downloads UEFI.zip 60.32 kB · 3 downloads Other copy.zip 1.92 MB · 2 downloads
So I have the Asus MSI H110m Pro VH Mobo, I am booting Big Sur Beta 3 from a 4g internal Hard drive. I created a vanilla usb installer and then from my Catalina I formatted the drive and installed BS onto the new drive. I used the methods from this post below and the pre-made Open Core efi from here and it works. Use the sudo instructions to create your own bootable usb don't download the image it gives issues.
MacOS Big Sur
Monterey
9 minutes ago, rositaott said:
can I restore in windows?
check if TransMac work
use a restore way. easy way
@MaLd0n Tô usando o Catalina com o Clover, e tô com duvida em duas coisas:
1 - No caso da atualização para o Big Sur, preciso atualizar a pasta EFI pra que seja compativel?
2 - Estou usando os bootargs: dart=0 -wegnoegpu alcid=66, sei que tem que adicionar também o -lilubetaall. Mas, existe mais algum bootarg necessário pra que o boot da instalação do Big Sur corra bem?
i5-8265U
8GB Ram
Intel UHD Graphics 620
1- sim. veja o primeiro post
2- só testando
On 7/3/2020 at 2:06 AM, MaLd0n said:
1- Download this .dmg and put in your desktop
Link 1- https://tinyurl.com/yxkeu853 BETA 3
Hi @MaLd0n, I downloaded the beta 3 dmg and proceeded the installation. But when I mount the dmg I dont see the EFI partition. Still I tried to restore it, but I don't see the EFI partition after restore in the ssd as well. Attached the diskutil list screen shot.
Disk3 is my internal SSD to which i am going to restore.
Disk4 is the dmg which i downloaded.
Disk0 is the Catalina OS on which I am trying the restore method
Screenshot 2020-07-28 at 7.24.03 AM.zip
