balikci922 Posted January 18, 2019 Posted January 18, 2019 Hello I have finally set up my Hackintosh, and I think it runs good. But sometimes, when I visit some pages it restart the computer, I have IGPU enabled, and when I disable the problem goes away. Also the cpu temp spikes up to 40-45 and down to 28-30 when opening apps and surfing. Im using iMac18.1 should I use ImacPro1.1? And I can't also don't control fans, the app says No Fans Detected and Istat doesn't have info about fans. Can somebody look at my EFI folder, and see if everything is as it should be? https://www.dropbox.com/s/5pbz49f5z2llozh/EFI.zip?dl=0 My build: Gigabyte Aorus Master i9 9900K Asus RX580 8 GB 32GB Vengeance 3000mhz
Administrators MaLd0n Posted January 18, 2019 Administrators Posted January 18, 2019 [ref]balikci922[/ref], use our clover folder for serie 30/300, reboot and extract files RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 18, 2019 Author Posted January 18, 2019 [ref]balikci922[/ref], use our clover folder for serie 30/300, reboot and extract files RunMe.app What do you mean by Extract files? And what about my config.plist should i make it from scratch again?
Administrators MaLd0n Posted January 18, 2019 Administrators Posted January 18, 2019 [ref]balikci922[/ref], follow instructions above and i configure ur hack for u -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 18, 2019 Author Posted January 18, 2019 [ref]balikci922[/ref], follow instructions above and i configure ur hack for u Can you link to the 30/300 chipset folder? I Can only see 20/30 series
Administrators MaLd0n Posted January 18, 2019 Administrators Posted January 18, 2019 [ref]balikci922[/ref], https://Olarila.com/forum/viewtopic.php?f=28&t=8222 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 18, 2019 Author Posted January 18, 2019 [ref]balikci922[/ref], https://Olarila.com/forum/viewtopic.php?f=28&t=8222 [/ I have downloaded the files, but when i look into the kext and driver folders, their is many kexts that i not use, should i just delete them? Also im using the free2000 optio, but in the folder it is aptiomemoryfix Added in 20 minutes 27 seconds: I have downloaded the files, but when i look into the kext and driver folders, their is many kexts that i not use, should i just delete them? Also im using the free2000 optio, but in the folder it is aptiomemoryfix
Administrators MaLd0n Posted January 18, 2019 Administrators Posted January 18, 2019 [ref]balikci922[/ref], yes -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 18, 2019 Author Posted January 18, 2019 [ref]balikci922[/ref], yes Okay, i will just delete the kexts i dont use, and replace the drivers64 with my own Added in 39 minutes 34 seconds: [ref]balikci922[/ref], yes I have added the Runme.app Log. Running Mojave, with Asus RX580 and IGPU i9 9900K gigabyte AOrus Master I have these kexts: AppleALC.kext FakeSMC_ACPISensors.kext FakeSMC_CPUSensors.kext FakeSMC_GPUSensors.kext FakeSMC_LPCSensors.kext FakeSMC_SMMSensors.kext FakeSMC.kext IntelMausiEthernet.kext Lilu.kext USBInjectAll.kext WhateverGreen.kext Driver64UEFI: ApfsDriverLoader-64.efi AudioDxe-64.efi DataHubDxe-64.efi EmuVariableUefi-64.efi FSInject-64.efi HFSPlus-64.efi OsxAptioFix2Drv-free2000.efi SMCHelper-64.efi Send me Furkans-iPro.zip
Administrators MaLd0n Posted January 19, 2019 Administrators Posted January 19, 2019 [ref]balikci922[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 19, 2019 Author Posted January 19, 2019 [ref]balikci922[/ref], DSDT.aml.zip But what about the config.plist, do you not gonna fix it?
onemanosx Posted January 19, 2019 Posted January 19, 2019 But what about the config.plist, do you not gonna fix it? not necessary unless specified by Mald0n Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
balikci922 Posted January 19, 2019 Author Posted January 19, 2019 not necessary unless specified by Mald0n What about all the things I don't need in config? It don't gonna be specified for my build? And what smbios do you think I should choose? iMacPpro1.1, imac18.1 or imac18.3?
onemanosx Posted January 19, 2019 Posted January 19, 2019 What about all the things I don't need in config? You can tweak at your own time. Use SMBIOS closest to your specs both iMacPro and imac18,3 works Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
balikci922 Posted January 19, 2019 Author Posted January 19, 2019 You can tweak at your own time. Use SMBIOS closest to your specs both iMacPro and imac18,3 works I have choosen iMac18.3. But when I try opening Final Cut, it just crash. And I cant still se my rpm speed in istat.
Administrators MaLd0n Posted January 19, 2019 Administrators Posted January 19, 2019 [ref]balikci922[/ref], https://Olarila.com/forum/viewtopic.php?f=62&t=7164 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 19, 2019 Author Posted January 19, 2019 [ref]balikci922[/ref], https://Olarila.com/forum/viewtopic.php?f=62&t=7164 Final Cut Works now, thank you! Only thing that don't work is I can't control my Fans, and I can't see the fans in istat, Mac Fans Cotrol app says that No Fans Detected
Administrators MaLd0n Posted January 19, 2019 Administrators Posted January 19, 2019 [ref]balikci922[/ref], u need a plugins sensors some apps dont work on it, the hackintosh dont have a smc, fakesmc or virtualsmc just emulate smc -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 19, 2019 Author Posted January 19, 2019 [ref]balikci922[/ref], u need a plugins sensors some apps dont work on it, the hackintosh dont have a smc, fakesmc or virtualsmc just emulate smc What to do than? Another problem i got, when i first boot up in Systwm Report > Graphics i could see both rx580 and uhd 630, after restart i only see rx580, why uhd dissapered?
Administrators MaLd0n Posted January 19, 2019 Administrators Posted January 19, 2019 [ref]balikci922[/ref], is a correct way for hardware accel -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 19, 2019 Author Posted January 19, 2019 [ref]balikci922[/ref], is a correct way for hardware accel In stat under it was listed as Intel UHD 630, now its listed GPU
Administrators MaLd0n Posted January 19, 2019 Administrators Posted January 19, 2019 [ref]balikci922[/ref], check in ioreg -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
balikci922 Posted January 20, 2019 Author Posted January 20, 2019 [ref]balikci922[/ref], check in ioreg Captura de Tela 2019-01-19 às 01.21.14.png Here is my fans, but not detected in Mojave
balikci922 Posted January 20, 2019 Author Posted January 20, 2019 [ref]balikci922[/ref], check in ioreg Captura de Tela 2019-01-19 às 01.21.14.png My usb 3.0 ports don't work, my usb and external hdd doesn't show up
erroruser Posted January 20, 2019 Posted January 20, 2019 read here https://Olarila.com/forum/viewtopic.php?f=79&t=7370 AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
