[ref]OzemirElion[/ref], one more, use this patch too in config.plist
change EC0 to EC
4543305f
45435f5f
disable hibernation
https://Olarila.com/files/Utils/disablehibernate.command.zip
master disable
master-disable.command.zip
repair permission
https://Olarila.com/files/Utils/RepairPermissions.zip
[ref]OzemirElion[/ref], see if this fixes the verbose messages. The messages should not cause any issues, though.
PS: Also remember the patches Maldon posted above.
Donate
Gitter Chat
MSI B360 Gaming Arctic
A bug: I have now connected the Notebook to the Charger and it is loading and increasing the Percentage, but the "Charging" icon is no longer appearing.
Adicionado a 2 minutos 7 segundos:
[ref]OzemirElion[/ref], does it only happen with new DSDT with working brightness slider?
Yep!
Sorry for being late. After running the "Repair Permissions" script Mac crashed a lot, it was slow ... I'm trying again ...
So far I'm waiting for him to have a successful boot without injecting Kexts, because by injecting them the Mac restarts at the end of the boot.
I think I need to repair the permissions via commands :(
Hello friends! Sorry for my disappearance ...
I had to reinstall the Mac after the Repair Permissions script because the system crashed and I could not start it anymore.
But the important thing is that the Patches worked. The Brightness Control, "Fn" Keys and Battery Indicator are working fine. The Battery Indicator has some bugs like "No lightning icon at the time of charging" or "100% battery discharge warning (see picture)", but they are random, they are no problem for me.
Can you guys help me with iMessage and Facetime? I have already followed many tutorials on SMBIOS, UUID, RtVariables, etc, but none solved iMessage / Facetime activation.
Hey guys! I'm back. Need your help! [ref]MaLd0n[/ref], [ref]onemanosx[/ref],
I need to enable the Gestures on My Touchpad. On VoodooPS2Controller the FnKeys works (Brightness, specifically), but on ApplePS2SmartTouchPad don't work (but the Gestures work) :(
Thanks, [ref]onemanosx[/ref]:)
Another issue (I'm sorry if I'm doing something wrong here): My Laptop has 1 USB3 and I could not get it to work properly. At the moment it is working as a USB2. What are the best ways to fix this?
Check out the link here
USB Fix
https://Olarila.com/forum/viewtopic.php?p=65287#p65287
Donate
Gitter Chat
