Hello MaLd0n,
Can you Suggest me How to Install 10.13.5 in my system? My System Configuration below please check...
intel core i7 4790K
gigabyte z97-d3h mobo
Zotac GTX 1060 6GB DDR5
16GB Corsair Vengence 1600Mhz Ram
120GB Adata Premiere 580 SSD
2Nos HP 22es IPS Monitor One Connected Via Mobo HDMI & Other Connected Via GTX 1060 HDMI Port
I need Intel HD 4600 Graphics & GTX 1060 Both r working Perfectly...
Waiting For Your Positive Reply....
Thanks in Advance
Hello MaLd0n,
intel core i7 4790K
Thanks in Advance
http://Olarila.com/forum/viewtopic.php?f=51&t=6393
Guys, Why I always get "Reboot and select a proper device please" when I try to boot clover from usb?
Use boot key and install clover in HDD/SSD
Mald0n,
First thing first, thank you for your raw image of High Sierra 10.13.5 that make it possible for me to install it on my laptop. Next is the thing that I'm not very good at. Could you please help me configure my DSDT and SSDT and also my config.plist? I use config3.plist to boot up, it's the original config.plist that I downloaded from above with adding some extra kexts and and kernel patches in config3.plist. I included an attachment of the output of RunMe.app that is needed to do this things. Thanks in advance
Mega: https://mega.nz/#F!ktshSAqb!9fp75vFaNZxbkXYCmwqYTQ
Mald0n,
check if work
CLOVER.zip
check if work
CLOVER.zip
Thank you for the help. I have tested it and found some good and bad news. The audio and mic are working normally. But the brightness, fn keys, usb2.0 ports, camera and bluetooth are not detected. Sleep and Shutdown also haven't work correctly either. Every time I shutdown, the screen goes blank but the HDD light indicator is still turned on and the fan is still spinning. That's what I found so far
send me new dump
RunMe.app
Sorry for the late reply. The time gap between Brazil and my place is quite different. Here is the new dump.
Mega: https://mega.nz/#F!h08nlTbB!UmV-TGlJ8XhdUBJ_XJOBDA
I'm now sure if this was the new dump, because I try the clover you sent me earlier in a flashdrive, I didn't put it in the internal hdd. So I generate a new one. But I'll try the DSDT you just sent e a few minutes ago first.
Okay, I will try this one right now
Wow, I'm really amazed. Thank you so much. Most of my problems are solved thanks to you but I still have a little problem:
QE/CI: OK
Audio: OK
Mic: OK
Brightness: OK
Usb 2.0 ports: OK
Usb 3.0 port: OK
Camera: OK
Bluetooth: OK
Wifi: OK
Sleep: Not Yet
fn keys: Not Yet
Trackpad: No trackpad found in prefpane
Shutdown: Can't shutdown normally yet
Sleep: Not Yet
fn keys: Not Yet
Shutdown: Not tested because I'm writing this reply.
what happens with sleep?
fn keys, u need debug and check what patch u need
trackpad, is a kext, just check what trackpad u have
It didn't sleep like it used to. In the previous hack, it was able to sleep like the display dim slowly and then the fan stop and hdd indicator turned off
My laptop also couldn't shutdown properly. Just like the previous hack.
Okay, I will do so
Thank you, I will look for the right kext for this problem
MaLd0n wrote: ↑10 Jun 2018, 23:23
Okay, I will do so
new dump, i'll check logs
Thank you. The only thing I changed was the ApplePS2SmartTouchpad.kext to solve the blank prefpane, it is not solved yet, but I'm still trying. Here is the new dump:
Mega: https://mega.nz/#F!sktjUZSD!fC7jOqUiMcGfxPtcgCHxUA
try
CLOVER.zip
for debug keys use it
DSDT.debug.zip
install it in Library/Extensions
ACPIDebug.kext.zip
reboot
now press ur correct keys brightness + and -
run in terminal
log show | grep -i acpidebug
paste result here
btw, i put voodoops2 kext, check if work
try
CLOVER.zip
Yes, will do
ACPIDebug.kext.zip
Where do I put this?
ACPIDebug.kext.zip
I have put it in L/E
DSDT.debug.zip
I still don't know where to put DSDT.debug. Do I have to replace DSDT.aml in patched folder?
run in terminal
paste result here
Last login: Mon Jun 11 11:33:43 on ttys000
ahmads-mbp:~ afuan-san$ log show | grep -i acpidebug
2018-06-11 11:23:51.893986+0800 0x21b      Default     0x0                  43     0    kextd: Kext rejected due to improper filesystem permissions: <OSKext 0x7f9a71d02790 [0x7fff9a587af0]> { URL = "ACPIDebug.kext/ -- file:///Library/Extensions/", ID = "com.rehabman.driver.ACPIDebug" }
2018-06-11 11:23:53.750426+0800 0x7123     Default     0x0                  1211   0    kextcache: Kext rejected due to improper filesystem permissions: <OSKext 0x7ff4a0e9cc40 [0x7fff9a587af0]> { URL = "ACPIDebug.kext/ -- file:///Library/Extensions/", ID = "com.rehabman.driver.ACPIDebug" }
2018-06-11 11:23:53.750773+0800 0x7123     Default     0x0                  1211   0    kextcache: ACPIDebug.kext does not authenticate; omitting.
Stangely, this is what happened to the trackpad
https://drive.google.com/file/d/1Ca3mFonlPwD2gsFeD53ymTn4Y051ZWNf/view?usp=sharing
Thank you for your time
u need run KextUtility for install debug.kext, just run
