Hello hackintoshers. I am about to try my first hackintosh. Has anyone installed MacOS Sierra 10.12.6 with Clover on a HP Z440 workstation (Xeon E5-1620 v4, Intel C612 chipset, Realtek HD ALC221 audio)? I am using a Sapphire Pulse Radeon RX 580 8GB. Windows 10 Pro is running now.
What kexts do I need? From countless threads and tutorials I have come up with this list:
AppleALC.kext
AppleIntelE1000e.kext
AtherosE2200Ethernet.kext
CoreDisplayFixup.kext
EFICheckDisabler.kext
FakeSMC.kext
IntelGraphicsFixup.kext
Lilu.kext
NullCPUPowerManagement.kext
RealtekRTL8111.kext
Shiki.kext
USBInjectAll.kext
VoodooHDA.kext
VoodooPS2Controller.kext
WhateverGreen.kext
XHCI-x99-injector.kext
Others I have seen:
AHCIPortInjector_v1.0.0.kext
IOAHCIBlockStorageInjector_v1.0.0.kext
NvidiaGraphicsFixup.kext
But I think some of these may be for laptops.
Is it a problem to install unnecessary kexts? Or the more, the merrier? Do I need to edit a DSDT? Or does Clover Configurator or multishit do this for me?
TIA
sorry for being late, my usb drive still dont show up on asmedia port
regards, Hendra
some old asmedia, nec etc, dont work more, if u can u try a genericxhci kext, but cause some problems
aldita wrote: ↑16 May 2018, 20:34
regards, Hendra
thank's MaLdon for the help
regards, Hendra
regards, Hendra
welcome
enjoy
EHC1 and EHC2 have no connections. Is that OK?
Hi @MaLd0n Thanks for this DSDT. I own the same motherboard just a minor glitch if please you help me to fix it.
I own Corsair 200R chasis which has 2 frontal USB3 ports and just one its working as 3.0 (2nd one). If i plug something on the first one, for example a blue pendrive in there isnt working only black ones 2.0. The rest its working great. Do we need to modify something in USBInjectAll or you need to modify something over DSDT? Thanks.
 macOS 10.15.6
*GA-Z87MX-D3H F7 - OpenCore  | i5-4570 |HD4600 | I217-V | ALC892 | |DELL SE2416H via HDMI|
send me files
Please, can you prepare a DSDT for my HP Laptop?
u need send me files generated in ur desktop, not .app
Sorry, that was stupid. File too large to upload, but you can get it here:
drop OEM
Hello. I have a similar problem with the black screen, but restart before the login screen.
I try too much things but nothing works
(Config: mb MS-7788, gtx 970, i5 3330, sierra 10.13.4)
I try Nvidiagraphicsfixup.kext and lilu as I see on tonycraps, still not working
>Cuda installed, Nvidia installed, Nvidiadriver checked on clover, key Nvidia add ok, nvda_rv=1 uncheck, Nvidia inject uncheck
use nv_disable and post files here
RunMe.app
Please help me.
dell E6420
HD3000
tks very
u have a good patches
I am completely new here and also beginner for installing Mac OS X on PC. Help me
I was trying to install Mac OS X Sierra that is 6.67GB in size.
My device Toshiba Satellite L745 (Intel Sandy Bridge Motherboard, i3 2310m processor, Intel HD 3000 Graphics).
Do any of you have the total walk-through that ensures the 100% successful installation??
Please see the video!!
use Olarila images 10.12.6, 10.13.2 or 10.13.4
That is a lot better. USB ports now working well. System seems stable on testing. Still have a couple of issues:
1) No screen brightness control
2) No Bluetooth working (Broadcom BCM94352HMB)
BRIGHTNESS.zip
BluetoothDevBroadcomInjector.kext.zip
Hi, for years I've been trying to make a Hackintosh but it never worked (I'll ways got stock on the log screen). I tried this 'High Sierra Olarila 10.13.5' release and somehow I made some progress, but now I'm stocked in this screen and I can't install it. It says, 'This version of macOS cannot be installed on this computer'. Can anyone please help me to solve this out?
Screen I'm stock and my PC hardware [Print Screen] - https://brunofelix20.tumblr.com/private/174520744744/tumblr_p9qd7lzLcg1ulwwqv
