Hello. I have a similar problem with the black screen, but restart before the login screen.
I try too much things but nothing works
(Config: mb MS-7788, gtx 970, i5 3330, sierra 10.13.4)
I try Nvidiagraphicsfixup.kext and lilu as I see on tonycraps, still not working
>Cuda installed, Nvidia installed, Nvidiadriver checked on clover, key Nvidia add ok, nvda_rv=1 uncheck, Nvidia inject uncheck
use nv_disable and post files here
RunMe.app
Please help me.
dell E6420
HD3000
tks very
u have a good patches
I am completely new here and also beginner for installing Mac OS X on PC. Help me
I was trying to install Mac OS X Sierra that is 6.67GB in size.
My device Toshiba Satellite L745 (Intel Sandy Bridge Motherboard, i3 2310m processor, Intel HD 3000 Graphics).
Do any of you have the total walk-through that ensures the 100% successful installation??
Please see the video!!
use Olarila images 10.12.6, 10.13.2 or 10.13.4
That is a lot better. USB ports now working well. System seems stable on testing. Still have a couple of issues:
1) No screen brightness control
2) No Bluetooth working (Broadcom BCM94352HMB)
BRIGHTNESS.zip
BluetoothDevBroadcomInjector.kext.zip
Hi, for years I've been trying to make a Hackintosh but it never worked (I'll ways got stock on the log screen). I tried this 'High Sierra Olarila 10.13.5' release and somehow I made some progress, but now I'm stocked in this screen and I can't install it. It says, 'This version of macOS cannot be installed on this computer'. Can anyone please help me to solve this out?
Screen I'm stock and my PC hardware [Print Screen] - https://brunofelix20.tumblr.com/private/174520744744/tumblr_p9qd7lzLcg1ulwwqv
please help me
audio inject via clover
install web driver
what do i have to do with the file?
clover/acpi/patched
Hi MaLd0n,
Could you please help me to create a good DSDT for my system? (Aurora R4 Dell Mobo). I've tried tons of DSDT's in order to boot High Sierra and I found the current one, but it's not optimized for my system (it says AMI Motherboard and mine is AURORA), so I have strange troubles like random reboots, USB3.0 not showing on USB devices (but working with some devices) and sleep not working. I've tried to apply patches to DSDT without luck (system won't boot).
I ran the SpeedStep and Turbo script from ssdtPRGen and I've working SpeedStep and Turbo modes by adding the resulting SSDT, the same with some USB trials that I did in the past (SSDT-2), but DSDT is still the one found in internet that doesn't match my Mobo but I keep it since it boots High Sierra and Clover 4509. Without DSDT system won't boot.
I've executed the RunMe.app script and attached the results on a link (forum doesn't allow me to upload 30MB file): https://www.dropbox.com/s/td7xxytqrslsf2o/Send%20me%20iMac.zip?dl=0
I would really appreciate your help. Thank you!!.
Hi MaLd0n,
I've executed the RunMe.app script and attached the results on a link (forum doesn't allow me to upload 30MB file): https://www.dropbox.com/s/td7xxytqrslsf ... c.zip?dl=0
very strange, i think u use dsdt from other mobo, different devices
CLOVER.zip
send me new SEND_ME after reboot with new folder
Yes, I didn't found any DSDT for my mobo so I tried lots of DSDT's until I found one that booted the MAC.
Booted with CLOVER attached. Here is the new log:https://www.dropbox.com/s/t2u9mqb9ivtlv3c/Send%20me%20iMac_NEW.zip?dl=0
Thank you!
Booted with CLOVER attached. Here is the new log:https://www.dropbox.com/s/t2u9mqb9ivtlv ... W.zip?dl=0
Thank you!
looks good, just check PM, i think need a Kernel XCPM
Yep, I've generated again with ssdprgen the SSDT for processor states and booted with -xcpm_ipi and it apparently is working in HWMonitor (see attached) and Intel PowerGadget.
Working also in 10.14 beta 1, so THANK YOU!!!!!!
Enjoy your beer :)
