2 port usb didnt work, maybe is from asmedia asm1042
regards, Hendra
need check if have patch for it, i think no, if dont work native u need a genericxhci kext, but this kext now cause some problems
send me new dump with new files
@MaLd0n please do help me with my audio. Got my Codec id and checked about AppleALC injection and all the guides is about realtek while I have a cirrus logic audio. Attached is an image and how do I go about it?
1196024659_IMG_20180512_230123675_HDR2.thumb.jpg.d6d04644dab3f3ed2c08082dd8a41eb3.jpg
aldita wrote: ↑13 May 2018, 05:58
regards, Hendra
here i send you a new imac
thanks
Send me iMac.zip
idk about ur codec, use VoodooHda, check InsanelyMac
thanks
replace, reboot and send me new dump, i need check
Hello hackintoshers. I am about to try my first hackintosh. Has anyone installed MacOS Sierra 10.12.6 with Clover on a HP Z440 workstation (Xeon E5-1620 v4, Intel C612 chipset, Realtek HD ALC221 audio)? I am using a Sapphire Pulse Radeon RX 580 8GB. Windows 10 Pro is running now.
What kexts do I need? From countless threads and tutorials I have come up with this list:
AppleALC.kext
AppleIntelE1000e.kext
AtherosE2200Ethernet.kext
CoreDisplayFixup.kext
EFICheckDisabler.kext
FakeSMC.kext
IntelGraphicsFixup.kext
Lilu.kext
NullCPUPowerManagement.kext
RealtekRTL8111.kext
Shiki.kext
USBInjectAll.kext
VoodooHDA.kext
VoodooPS2Controller.kext
WhateverGreen.kext
XHCI-x99-injector.kext
Others I have seen:
AHCIPortInjector_v1.0.0.kext
IOAHCIBlockStorageInjector_v1.0.0.kext
NvidiaGraphicsFixup.kext
But I think some of these may be for laptops.
Is it a problem to install unnecessary kexts? Or the more, the merrier? Do I need to edit a DSDT? Or does Clover Configurator or multishit do this for me?
TIA
sorry for being late, my usb drive still dont show up on asmedia port
regards, Hendra
some old asmedia, nec etc, dont work more, if u can u try a genericxhci kext, but cause some problems
aldita wrote: ↑16 May 2018, 20:34
regards, Hendra
thank's MaLdon for the help
regards, Hendra
regards, Hendra
welcome
enjoy
EHC1 and EHC2 have no connections. Is that OK?
Hi @MaLd0n Thanks for this DSDT. I own the same motherboard just a minor glitch if please you help me to fix it.
I own Corsair 200R chasis which has 2 frontal USB3 ports and just one its working as 3.0 (2nd one). If i plug something on the first one, for example a blue pendrive in there isnt working only black ones 2.0. The rest its working great. Do we need to modify something in USBInjectAll or you need to modify something over DSDT? Thanks.
 macOS 10.15.6
*GA-Z87MX-D3H F7 - OpenCore  | i5-4570 |HD4600 | I217-V | ALC892 | |DELL SE2416H via HDMI|
send me files
Please, can you prepare a DSDT for my HP Laptop?
u need send me files generated in ur desktop, not .app
Sorry, that was stupid. File too large to upload, but you can get it here:
drop OEM
