Hi Maldon
I reinstall macos sierra and it works.
That'sthe new runme.
looks good, what not work?
have a some acpi errors, we can solve it, but need some tests
UPDATE FIRST POST
-Clover folder
-Kexts
-Patches
Hi maldon
I installed high sierra 10.13.3 but I can’t do update 10.13.4
Help me
delete files in root of the HD and download again
Hi Maldon
I did that and its update 10.13.4 but I have a prblem with nvidia gtx1050
How can I install the nvidia video
Hi Maldon
is a optimus? if yes, u need use intelHD and disable Nvidia
Hi Maldon
I checked with maciasl DSDT and I found error and differents warninig
could you check it and tell me how can I resolve it
MaciASL.app.zip
Hello, I'm installing on
HP Pavilion dv6-6b66ew
8GB DDR3
i7 2670QM 2.2Ghz
Intel HD 3000 / Radeon 6770m 2gb ddr5
128 GB SSD + 320GB HDD
Have the problem during installation process, it stucked as on screenshot then start to be stop symbol and says that waiting for root device
31717530_1889427831076167_6641713705430024192_n.jpg.00b2123f5b80251185d111e97ac3fa31.jpg
8GB DDR3
i7 2670QM 2.2Ghz
ahci? u disable dgpu?
I already found a problem, it was cause I was putting stick in 3.0 port, have to do it otherwise with extracting the whole image to 2nd hdd and boot from it. Ok now I'm a bit stacked what to do next after installation. I can't install clover, IDK why
Here the installation log
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *31.7 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS macOS High Sierra 10... 6.9 GB disk0s2
/dev/disk1 (internal, physical):
0: GUID_partition_scheme *120.0 GB disk1
1: EFI EFI 209.7 MB disk1s1
2: Apple_APFS Container disk2 119.8 GB disk1s2
/dev/disk2 (synthesized):
0: APFS Container Scheme - +119.8 GB disk2
Physical Store disk1s2
1: APFS Volume Macintosh HD 14.3 GB disk2s1
2: APFS Volume Preboot 20.8 MB disk2s2
3: APFS Volume Recovery 503.9 MB disk2s3
4: APFS Volume VM 20.5 KB disk2s4
Backing up EFI files
Backing up /Volumes/Macintosh HD/EFIROOTDIR/EFI folder to /Volumes/Macintosh HD/EFI-Backups/r4449/2018-05-02-03h30/EFI
ERROR: /dev/disk2s1 use an unsupported partition scheme: EF57347C-0000-11AA-AA11-00306543ECAC
Hi MaLd0n, I'm on 10.13.4 and I have problems with my DSDT, I think. Found it online and it's the only one with I can boot my hack. Could you take a look at it, please? I didn't manage to enable power menagment too. Tried with Piker's script and with Clover options with no results.
Specs:
Runing x79-b10
Intel Xeon E5-2687W 8 cores 3,1GHz
Zotac GTX 1060 6GB
Send me Lorenzos-Pro.zip
Specs:
Runing x79-b10
Zotac GTX 1060 6GB
CLOVER.zip
x79 is a problematic chipset for Power management
CLOVER.zip
(1.72 MiB) Not downloaded yet
Thanks for your help ;-). Try it now and let you know. For PM, do you have any suggestion?
EDIT: I replaced my Clover folder with this but I have kernel panic.
EDIT 2: I can boot only if I change TSCAdjustReset with VoodooTSCSync but I have issue I had.
These are some screenshots about my issues and clover bootlog file.
Sometimes boot hangs in that way and I can move my mouse but not click. When I open an app, I have a sort of resize lag (sometimes it opens normally, sometimes it stops opening in a mini windows, like CC in the picture, sometimes it stops and remains like a bigger icon on the screen, like Geekbench).
EDIT: Ok, I tried to change VoodooTSCSync from 15 to 7 in info.plist and now seems that my hacks works really well. No resize lag or crash, I can see video on youtube while I didn't before. No PM because in Intel Power gadget the frequency is always at 3,1GHz.
1873073028_ScreenShot2018-05-02at17_32_38.thumb.png.2755771faf64908a92ac885cdd179bfd.png
2013831795_ScreenShot2018-05-02at17_40_29.thumb.png.abf63e7ce8e6c8871f274b11cd59be37.png
2070519052_ScreenShot2018-05-02at17_40_45.thumb.png.a2ad810e3ef39f066b3412176ecb594c.png
1674511296_ScreenShot2018-05-02at17_45_26.thumb.png.8a1a1b078eaf54ce72ab4279d723db32.png
bootlog.log.txt.zip
771766044_ScreenShot2018-05-02at17_54_50.thumb.png.f1ba548732fb4e647598671524948532.png
gtx1060 have some problems in osx, some ppl solve it with ERP options in bios
[]send me new full dump with app
