@MaLd0n thank you so much for your earlier work with my Kaby Lake hackintosh everything was working smoothly before, but now with your DSDT I feel it has greater stability. I have an HP Probook 4540s hackintosh laptop working a for a couple years now and it has been working great thanks to Rehabman and his patches. I wanted to know if possible if you could make a DSDT for this laptop for improved stability overall? Attached is my SendMe app data.
HP Probook 4540s w/ High Sierra 10.13.4
16 GB of 1600Mhz DDR3 Ram
Intel Core i7 3720-QM@ 2.6 Ghz (Turbo Boost 3.6 Ghz)
Broadcom Wifi/BT Card (BCM94352HMB)
480GB Sandisk SSD
500GB Time Machine Backup on Samsung 850 EVO SSD
Apple Magic Mouse 2
Send me Seans-Hackbook-Pro.zip
u have a good system, only one comment, use USBInjectAll.kext or FakePCIID_XHCIMux.kext, never both
Thank you I will make the necessary change immediately.
Hi maldon,
I have asus Laptop fx502vm corel i7 7700hq hd 630 - nvidia gtx1050 4gb - hm175
I installed sierra 10.12.6 (external samsung ssd 850 evo) but it is basic setup and I want to start a new install.
could you help me to setup config.plist and efi
My laptop 7347
CLOVER.zip
Hi maldon,
http://Olarila.com/forum/viewtopic.php?f=50&t=6257
hi Maldon
I check the guide and I send RunMe
CLOVER.zip
send me new SEND_ME after reboot
use -v
is a usb problem
drop DSDT first, press O key in Clover boot screen, go to Acpi Patching/DSDT Name and put DSDT02.aml
and remove DSDT.aml in Clover/acpi/patched
Hi, I'm on 10.12.6 and I have many problems with grapichs and powermenagment. I tried many solutions but with no results. I was on 10.13.4 and I downgraded to try if the problems were about last update, but I have same issue now, as I said. Here are the .zip you request and my clover folder without themes. Could you help me, please?
S/Ns are random
Send me Lorenzos-Pro.zip
CLOVER.zip
