Thank you Mirone,
Errors are about sound assertion. The sound itself is working correctly.
Regards, Aldebaran
to avoid it use:
com.apple.driver.AppleHDA
536F756E 64206173 73657274 696F6E20
00000000 00000000 00000000 00000000
Patch Assertions
10.11.x,10.12.x,10.13.x
and
com.apple.driver.AppleMikeyDriver
Patch Assertions
MaLdOn,
Everything is working fine. But looking to everymac I realized that iMac15,1 would be a better match.
What do you suggest. To change the SMBIOS section or not? If yes should I use Clover configurator to generate new SMBIOS?
Regards, Aldebaran
14 or 15 work good ;)
Hi everyone,
I have this Hackintosh
Huanan X79 Deluxe
Intel E5 2680 v2
32Gb DDR3 1333 ECC
Asus Nvidia GTX 960 2Gb
I have installed macOS 10.13.3  I think all work more or less (usb 3.0 not works), but the problem is with processor because always work 2,8Ghz without turbo boost
I don’t see a lot of information about Huanan motherboards and X79 (C602 really).
vvI57dq.jpg&key=a822dd3d75e9a730c53a3be35c8d2ad2feb32dd0600663717ccda560d9581c8d
This is my configuration. Can anyone help me?
Send me Mac-Pro.zip
test usb3 with dsdt, usb3 is load in ioreg, what happens?
Power Management
https://www.insanelymac.com/forum/forums/topic/324270-sandy-bridge-e-ivy-bridge-e-power-management-1013-appstore-release/
Singal VGA GTS 450 HDMI or DVI-I
i think ur GPU loose support in new system
and the sierra works normally
stay in sierra, loose support in high sierra
u need a support, without support don't work, don't have miracle in Hackintosh
(10.87 KiB) Downloaded 1 time
Power Management
https://www.insanelymac.com/forum/forum ... e-release/
Before when I connect one pendrive usb 3.0, say me not enought power but with new dsdt is ok, I don’t know what was the problem.
I tried with power managment but I don’t get nothing, I don’t understand what can I do more.
Also, I did this tutorial https://www.tonycrapx86.com/threads/guide-x79-os-x-controlled-speedstep-cpu-power-management.127574/
Only cpu all the time 2,8Ghz/2,64Ghz
573608537_Capturadepantalla2018-04-02alas0_34_37.png.5a3ccbef5e50af5dba46bfb2f6472b0a.png
-FIX ERRORS AND WARNINGS
-HPET
-SATA
-DMAC
-SLPB
-DARWIN
-EHCI
-XHCI
-PLUGIN TYPE
-XXXX to HDEF
-HDEF
-RTC
-IRQs
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-USBX
-IMEI
-EC
-PNLF
-GFX0
-HDAU
-NVME
-ARPT
-INTELHDGRAPHICS
where patched DSDT IVYBridge speed high sierra 10.13.4 problem not install error
