HDAUniversal - AppleHDA-like Audio Kext for macOS Tahoe and Hackintosh Systems
Enable sip after installation
i installed with 03080000 after install i rebooted , and change back to 00000000 sound no audio output , kext disabled i think , with 0308 kext working
my laptop uses an ALC255, alcid=99, macOS 26.6.1, opencore, kext installed properly on /library/ext
Headset microphone is not detected on a combo-jack laptop, i've been test using other alcid bug still present,
only internal microphone is detected and no response on line in microphone.
hadn't issue with sound so far, only the headset mic.
thank you
HDAUniversal-Fast-Diagnostics-2026-09-08_14-55-22.zip
These configurations comming from a layout. Check if ur layout have a correct things. In some cases to detect all ports, etc need check from linux and connect headset, test mic, etc then extract codec dump.
has anyone succefully installed mac os ventura on macbook pro 2011 macbook pro 8,1 . mine installed well but on last reboot doesnt reach setup, it hangs on progress bar around quaterway
here the codec dump
alsa_dump.zip
1 hour ago, Matheiez said:
here the codec dump
HDAUniversal-Release.zip use alcid=171
Alc layout id 13 worked for me with applehda and applealc. I get no sound device with HDAUniversal. Please check my linux dump, if I need to use another layout id. Thank you very much!
Edit: codec is Realtek ALC3281-CG in a Dell Precision 5550
codec_dump_0.zip
Edited by STEPHANVS
Hi every one! newbie here just for curiosity. There is some way to boost volume ?
Because I have some hearing issues and for me is this too low, either using HDA Universal or AppleALC or VoodooHDA had the same volume .
Thanks you!
Edited by Valderdark
HDA-Universal has native volume, without boost or -dB adjustment.
Thanks you!
Try VoodooHDA with VoodooHDAEnableHalfVolumeFix set to true.
