Hi guys,
A new version of ESP Mounter is ready for test, added bunch of new features:
1. You can add auto-mount for any of your USB/External disks and when the disk is mounted and the ESP mounter is loaded it will automatically mount the EFI folder and it can also open the config.plist with the default plist editor
2. You can set auto-mount enable or disable
3. added disk space and smart indicators
4. You can erase the EFI partition or the whole disk within the app (be careful using this feature)
5. When the app is loaded you can open the menubar with option+command+E shortcut
6. Improved system info detection logic
7. Updated donation QR-Code and URL, the previous donation links were confusing for some
8. Improved disk detection logic for faster disk detection
I hope you enjoy using the new Bootabler.
Looking forward to your feedbacks and appreciate your support if you feel like it.
Updates are available through the app and the link in the first post.
  • Like 2
MacMeUp.com My Apps: Optimo, Bootabler (Bootable USB/ISO Maker), Mac Tweaks v.3, ESP Mounter, Donate
update
  • Like 2
CPU Intel Core i5-13600KF Raptor Lake / Motherboard Gigabyte Z690 Gaming X DDR5 / Graphics Card MSI RX 6600 XT / Ram Kignston DDR5 32GB / Fenvi T-919
macOS Thaoe 26.7.1 /macOS Sequoia 15.8.1 /macOS Ventura 13.7.8 /macOS Thaoe 26.7.2 Beta /Windows 11 Pro
update 2.5.7
Hi guy,
There is a new and improved version on ESP Mounter available for download, you can also use the built-in update feature to update to the latest version.
Disk detection as fast as Disk Utility
Disks are read directly from macOS instead of through dozens of command-line queries. The list appears much sooner at launch, and connecting or removing a drive updates almost instantly.
Faster EFI mount and unmount
Mounting and unmounting now take a single step, and most EFI partitions no longer need your administrator password.
Reliable on macOS Tahoe at login
Fixed the menu bar icon sometimes not responding when ESP Mounter starts with your Mac, and removed several causes of slow or frozen launches on macOS 11 through 26.
More accurate filesystem detection
Filesystems are identified by their real partition type. Each type gets its own badge, exFAT drives are no longer labeled as Windows, and MBR-formatted USB drives show their volume names.
and a lot more
