Easy way to enable audio in macOS Tahoe
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Why Olarila doesn't support TonyMac, Reedit, Little-Translated and others HERE
1. Download Mykextinstaller HERE
2. Download AppleHDA.kext HERE
3. Set the csr-active-config and alcid in NVRAM tab to 03080000. Check HERE about correct alcid for your audio codec.
4. Enabled AppleALC.kext in OpenCore under the kernel tab.
5. installed the AppleHDA.kext with Mykextinstaller. (the prompted to locate the kext I wanted to install so I already have copied the file to my desktop)
6. Rebooted the system when the kext was installed and done.
We're all here to have fun and learn from each other! That's all Folks!
Credits:
  • Like 10
  • Thanks 1
U don't need this on Sequoia.
@MaLd0n
Good morning, my friend, let me ask you... can I set this Kext only to start with MacOS 26?
Like, in the kernel, can I set the maximum and minimum kernel to 26.0.0 and have AppleALC remain normal?
By the way… is OCLP working normally with MacOS 26?
Edited by alebypegasus
Yes. In the kernel tab.
No. Have a mod version. But this idea is not using it. Stay with clean system with only these kexts.
This applies to hackintosh as well right? Vodoo isn't detecting my microphones.. I had to go through hell to get back into beta 1 from beta 2... So now I would like to upgrade to beta 4, but first I need the audio to be fixed while in beta 4.. so doing my research.. came across this from a yt video showing how to install audio for non T2 macs.. so I would like to know if its applicable to the hackintosh as well or solely to macs...
Hackintosh yes
Yes
  • Thanks 1
Fixed!
I have same error , "not authorized to send Apple events to Finder"  Tahoe Beta  Version 26.0 (Build 25A5346a)
Pryvacy-Security -Automation  is empty
csr-active-config in NVRAM tab is 03080000
Tks.
Help on How to Fix AppleHDA Enable Audio macOS Tahoe 26 (25A354)
Motherboard: Asus prime B250M-A, CPU: INTEL I3-7100, RAM: 16 GB, Intel HD Graphics 630
Realtek ALC887
Edited by Sequoia24
Steps on first post
