kromakey Posted April 3, 2014 Share Posted April 3, 2014 Olá , estou precisando de ajuda , so consigo dar boot com -v -f para entrar no Mavericks se nao escrever nada , nao entra . se escrever -s aparece : missing Bluetooth controller transport Minha maquina : Motherboard GA-Z87X-UD3H Intel Core i7-4770K GeForce GTX 760 16GB 1866MHz DDR3 (8x2) SATA 6Gb/s 120GB SSD Fonte : 650 Watt TP-Link PCI Express Wifi Adapter obrigado GA-Z87XUD3H 16G Ram GeForce GTX 760 2048-Corei7SierraCapitanYosemite-Win10-Remix OS GA-EP45-DS4 4G Ram 9600GT-QQ6600Capitan-Win10 Facebookhttps://goo.gl/sXzktO KODIhttps://goo.gl/zw5Utl Link to comment https://olarila.com/topic/3308-missing-bluetooth-controller-transport/ Share on other sites More sharing options...
artur-pt Posted April 3, 2014 Share Posted April 3, 2014 olá desabilita na bios a igpu ou onboard graphics para subir com a nvidia deve subir com GraphicsEnabler=No bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment https://olarila.com/topic/3308-missing-bluetooth-controller-transport/#findComment-35816 Share on other sites More sharing options...
kromakey Posted April 3, 2014 Author Share Posted April 3, 2014 segui este manual para a configuraçao da bios 2. Enter the Bios and Press F2 to load the Classic View 3. Press F7 to load optimized default values then proceed to change it. 3.1. Under Peripherals > xHCI Mode, change it to AUTO 3.2. Under Peripherals > xHCI Hand-OFF, change it to ENABLED 3.3. Under Peripherals > EHCI Hand-OFF, Change it to Enabled 3.4. Under Peripherals > Internal Graphics, Change it to Disabled. 3.5. Under Peripherals > Init Display First, change it to the PCIe slot that you placed your graphics card in. 3.6. Under Power Management > Wake on Lan, change it to Disabled. 3.7. Under BIOS Features > Boot Options, change it to your boot disk but pick the one that starts with P2 or some number like that. - Do not select the UEFI version else you will get the missing operating system error. 4. Save and Exit Bios. a grafica que esta a carregar é a correcta : NVIDIA GeForce GTX 760: Chipset Model: NVIDIA GeForce GTX 760 Type: GPU Bus: PCIe PCIe Lane Width: x16 VRAM (Total): 2048 MB Vendor: NVIDIA (0x10de) Device ID: 0x1187 Revision ID: 0x00a2 ROM Revision: preset 1.0.0 nao será outra coisa ? GA-Z87XUD3H 16G Ram GeForce GTX 760 2048-Corei7SierraCapitanYosemite-Win10-Remix OS GA-EP45-DS4 4G Ram 9600GT-QQ6600Capitan-Win10 Facebookhttps://goo.gl/sXzktO KODIhttps://goo.gl/zw5Utl Link to comment https://olarila.com/topic/3308-missing-bluetooth-controller-transport/#findComment-35825 Share on other sites More sharing options...
kauchaos Posted July 21, 2014 Share Posted July 21, 2014 Estou com um problema parecido, antes de instalar eu tenho que bootar com GE=Yes, depois que instalar e subir pra primeiras configurações, eu tenho que desabilidar com GE=No, se não nao sobe nem a ..... mas ai vem o problema, depois que configurado e tal, ele sobe de vez em quando com o GE=YES isso quando nao trava na maça... mas mesmo subindo nao acho minha gtx no sistema, sabem como resolver isso?? Link to comment https://olarila.com/topic/3308-missing-bluetooth-controller-transport/#findComment-39480 Share on other sites More sharing options...
flaviocdac Posted August 6, 2014 Share Posted August 6, 2014 Habilitem a Gráfica Onboard na BIOS, e bootem com GE=No.... Deve resolver o problema! DualBoot: Win 10 Pro X64 & El Capitan 10.11.6: GA-H87M-HD3 - Intel Core i5 3,19 GHz Haswell - 16GB 1600Mhz - 240GB SSD Kingston + 4TB HD - GTX650 2GB 128Bits - LG 25UM65 (2560x1080) iPadAir 32GB iPhone 6S 128GB Link to comment https://olarila.com/topic/3308-missing-bluetooth-controller-transport/#findComment-39916 Share on other sites More sharing options...
