alc269 does not work
nmz1
Mirone
There is a group of us trying to get Acer V5-171 11.6" laptop working. Everything seems to work now except Sound and Sleep. We think we need a DSDT but no-one understands how to and how to edit kext for our ALC269. Could you PLEASE help? PLEASE?
DSDT for BIOS 2.13 attached. I will promise to test AND respond (unlike last poster!)
dsdt.7z
Link to comment
Share on other sites
Mirone
I need your codec_dump extracted through Linux.
and your DSDT.
Link to comment
http://www.insanelymac.com/forum/topic/46378-how-to-get-a-linux-codec-dump/ - I followed this process and there were two codecs... Attached with DSDT in single 7zip
No edits done to DSDT (no idea how!)
Thanks for your help and prompt response
here's your DSDT + AppleHDA corrected
try and let me know if it worked for you.
http://www.sendspace.com/file/9pi87d
Link to comment
I tried and my internal speaker worked. Thanks so much Mirone. I haven't tried internal mic yet as I faced another issue: my USB ports and webcam camera, which had worked OOB, didn't work anymore.
I guess it could be the dsdt.aml. I have extracted dsdt.aml for my laptop before I tried the one you gave me. Could you help adding stuffs to my extracted dsdt.aml? Thanks.
Fujitsu_dsdt.zip
Link to comment
what's your setup?
pass me the specs of your notebook.
Link to comment
My notebook is Fujitsu LH532: Core i5-3210M CPU, HD4000, FJ Webcam, ALC269, Ralink RT3290LE (I'm ordering an Atheros AR9280 AR5BHB92) and Realtek PCIe GBE Gigabit LAN. Among those, HD4000, ALC269 and Ralink RT don't work. So I added a hex string in boot.plist for HD4000, and used the patch you gave me for ALC269.
It has ML10.8 and Windows 8 dual boot.
Update 1:
- I copy this method from DSDT.aml file you sent to me to my DSDT's HDEF section
Store (Package (0x06)
"hda-gfx",
Buffer (0x0A)
"onboard-1"
"layout-id",
Buffer (0x04)
0x0C, 0x00, 0x00, 0x00
"PinConfigurations",
Buffer (Zero) {}
}, Local0)
Return (Local0)
My ML is now working ok; webcam, USB work with no kernel panic.
Update 2:
Internal Speaker and headphone worked. Internal mic and external mic didn't work. The system recognized external mic when I plugged it in and turned back to internal mic when external mic was plugged out. However, I couldn't see any signal for mic.
Is there any solution for my mic? Thanks.
Link to comment
Update 1:
"hda-gfx",
Buffer (0x0A)
"onboard-1"
"layout-id",
Buffer (0x04)
Buffer (Zero) {}
}, Local0)
Return (Local0)
Update 2:
Try this: http://www.sendspace.com/file/d8loes
Link to comment
Thank Mirone for your work. The second kext didn't work. It was even worse.
My OSx86 indicated no input.
With the previous kext, it recognized Internal Microphone
and Line in.
When I plugged in or plugged out a line in, I could see signal bar changing.
The only problem was that the microphone or a line in couldn't pick up any signal when I spoke to it.
Link to comment
ALC269 is not working for me in AppleHDA forum ..
i cannot get codec_dump as i dont have linux.. how can i get it in windows ?? and i can extract my DSDT from Mac Os X...
Acer Aspire v5-571P
Intel Core i5-3317U @ 1.70GHZ
6GB RAM
500GB HDD
Windows 8 64Bit
Link to comment
