Homam Salahie Posted September 3, 2020 Posted September 3, 2020 Hello Sir , I hope you and your loved ones are doing well. This is my laptop specs : Acer Aspire V3-574G-56F3 Part Number: NX.G1UEY.002 Processor Processor Manufacturer Intel® Processor Type Core™ i5 Processor Generation 5th Gen Processor Model i5-5200U Processor Core Dual-core (2 Core™) Processor Speed 2.20 GHz Maximum Turbo Speed 2.70 GHz Cache 3 MB Direct Media Interface 5 GT/s 64-bit Processing Yes Hyper-Threading Yes Memory Standard Memory 8 GB Maximum Memory 16 GB Memory Technology DDR3L SDRAM Number of Total Memory Slots 2 Memory Card Reader Yes Memory Card Supported SD Storage Drive Type HDD Total Hard Drive Capacity 1 TB Hard Drive Interface Serial ATA Hard Drive RPM 5400 Optical Drive Type DVD-Writer Display & Graphics Screen Size 39.6 cm (15.6") Display Screen Type LCD Aspect Ratio 16:9 Screen Mode HD Screen Resolution 1366 x 768 Backlight Technology LED HDCP Supported Yes Graphics Controller Manufacturer NVIDIA® Graphics Controller Model GeForce® 940M Graphics Memory Capacity Up to 4 GB Graphics Memory Accessibility Dedicated TV Card No Network & Communication Wireless LAN Yes Wireless LAN Manufacturer Qualcomm Atheros Wireless LAN Model NFA344 Wireless LAN Standard IEEE 802.11ac Ethernet Technology Gigabit Ethernet Bluetooth Yes Built-in Devices Front Camera/Webcam Yes Microphone Yes Finger Print Reader No Speakers Yes Number of Speakers 2 Sound Mode Stereo Interfaces/Ports HDMI Yes Total Number of USB Ports 3 Number of USB 2.0 Ports 1 Number of USB 3.0 Ports 2 VGA Yes Network (RJ-45) Yes Software Operating System Platform Windows Operating System Windows 10 Home Operating System Architecture 64-bit Input Devices Keyboard Yes Pointing Device Type TouchPad TouchPad Features Multi-touch Gesture Battery Information Number of Cells 4-cell Battery Chemistry Lithium Ion (Li-Ion) Battery Capacity 2520 mAh Power Description Maximum Power Supply Wattage 65 W Physical Characteristics Height (Front) 23.90 mm Height (Rear) 23.90 mm Height 23.90 mm Width 381.6 mm Depth 259 mm Weight (Approximate) 2.40 kg Miscellaneous Package Contents Aspire V3-574G-56F3 Notebook Lithium Ion Battery AC Adapter Certifications & Standards ACPI 3.0 I have installed macOS Catalina 15.5.6 on my laptop Acer Aspire V3-574G Legacy mode as UEFI wouldn’t work for me . I used Vanilla Image Olarila ( Clover ) I boot to the Hackintosh successfully with no issues , Copied the EFI from the USB Install Catalina to my SSD where I installed the Hackintosh and reboot . What Worked from the start: - Ethernet What I had to install Kext : - Audio (Works good) - USB (Works good) Issues I have : which I need fixes for. - Brightness is so low , can’t control it to make it higher , When I boot to macOS on the logo brightness is fine till the loading bar reach half it dims and goes to really low brightness ( I have tried installing the kext IntelBacklight.kext and also tried AppleBackLightFixUp.kext) and added SSDT-PNLF.aml to my ACPI/Patched , but nothing worked - TrackPad ( laptop mouse pad ) works fine but with no functions like scrolling down for up , using commands like 3 fingers to switch to another desktop or anything like that. - Microphone and webcam doesn't work - WiFi doesn’t work doesn’t even show in settings , my laptop wifi card is ( Qualcomm Atheros QCNFA34AC ) - Nvidia GeForce , ( I have Nvidia GeForce 940M 4GB ) - I have Intel HD 5500 ( I5-5200U 2.2GHz ) I’m not sure if it’s Working on the Hackintosh or not , but everything is smooth and I can see the transparency in dock also in launchpad , I have also installed Photoshop and it works fine so for the intel I think its working good . Now this is everything with my Hackintosh , it’s amazing I just want those fixes , for my Hackintosh and any further advices from you to make it perfect , if I get those fixes I think Hackintosh will be my daily used machine Here is a link to all the files I could provide of my Hackintosh , my used ( EFI , RunMe , also System/Library/Extensions ) if you need any further files I can provide please let me know , https://drive.google.com/drive/folders/1VUQlYprb9E8N_keLFUNYbU-iBpTfaX5d?usp=sharing
