7 hours ago, quan0509 said:
Sir
u have a full patches. ur config looks good
15 hours ago, quan0509 said:
Sir;
I follow & use your files to build b460 with iGPU but my Hackintosh Pasted Graphic.png.zipdetect the system with CPU core i9 6 cores, but my system is only core i5 - 10600.
By the way, I posted the full dump here, please kindly support to get the full patch
https://www.mediafire.com/file/rd6z1fmejvbe7rs/Send_me_Mac.zip/file
How to revise it to the right spec?
Have you tried airplay yet? Does it work stably? My device is identical to yours and currently when airplay is output it only sounds no screen signal, when I turn it off, the screen still shows the last connection
Edited by huyxom
6 hours ago, quan0509 said:
so how to change cpu detect from i9 to i5 (my CPU is i5 10600) not i9.
cosmetic
u can change cputype
24 minutes ago, czerwus said:
Hi guys. Any chance for DSDT patch for bios F5d of this mobo?
update bios and post one full dump here
8 hours ago, czerwus said:
Thank U so much, sir. Need to use WeTransfer due to limited file size.
9 minutes ago, czerwus said:
Hello Sir. Please check your DM.
Hey
Check there
yes with 10th gen processors
1 minute ago, mengshi said:
This looks like the build I will be making as this motherboard is easier to find now. The M.2 stuff working?
yes with good nvme all working very nice
1.) May I ask what is the "problem" with the B460 for it not to be in the usual recommended list as the H470 or Z490 ? (Both of these are rather hard to source where I live).
A few points going forward ....
2) It is lacking the SPDIF header which I am using on my Z97 at the moment (ALC887 also) but for sound I am prepared to go the USB DAC route which in many ways is easier anyway. One can get really good quality USB DAC dongle cheap nowadays.
3) I don't think usage of Thunderbolt related devices are of any concern for me so spending more for the Z490 for these are pointless
4) Single M.2 is probably adequate. I rarely boot into Windows.
5) I will be "migrating" my perfect Z97-HD3 (Thanks MaLd0n for the great DSDT for this) with its RX580 and Wifi/BT PCI card over to this. I think should be not too difficult. Am I missing anything or will I be missing anything?
6) BTW, thinking of using the i3-10105..... or should I just get a used Xeon 1285L v4 in the Z97? It is about the same power (sort of) as the i3-10100 at 65W as well.........
all mobos gigabyte or asus
h410 for example is very nice too
i never use this xeon
6 hours ago, onixs said:
can you please provide the clover zip file
https://www.olarila.com/topic/5676-hackintosh-efi-folders-for-all-chipsets-clover-and-opencore/
28 minutes ago, Karl Pitt said:
Gigabyte h510 m intel i5 10500 8gb ram igpu uhd630
IGPU don't work in this case. U need add one GPU like RX560 with native support.
On 2/12/2023 at 9:29 AM, Karl Pitt said:
I have AMD R9 370 BUT SAME PROBLEM
THANKS
hi fixed the gpu issue by swapping it for rx580 which works out the box but have a problem with wifi.
iv got greyed ou wifi symbol which I can toggle the on off switch but 0 scan results pic card is ax210 wifi and bluetooth
sorry thanks in advance
