Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
A very custom DSDT for best experience under macOS. Removed all unused devices, injected all Apple devices, essentials, cosmetics, real improvements.
Cost Benefit.
Good performance.
-OpenCore Vanilla TUTORIAL-
-USB Port Mapping TUTORIAL-
-USB Solution for H410/B460 Chipsets-
a- Use these kexts
b- Reboot
c- Follow this tutorial and use SSDT-UIAC.aml instead USBPorts.kext
-Bios/UEFI Settings-
CSM Support - Disabled
Internal Graphics - Enable
-Hardware-
Mobo - Gigabyte GA B460M DS3H
https://tinyurl.com/yygxbpwr
Processor - Intel Core i9 10900
https://tinyurl.com/y42oabk9
GPU - Gigabyte 5500XT
https://tinyurl.com/y2s3t7wb
Cooler - CoolerMaster Hyper T4
https://tinyurl.com/ryne7zk
NVME - Lexar NM610 NVME
https://tinyurl.com/y3jyfbzd
-Power Supply - Corsair CX750
https://tinyurl.com/y3yh6r7j
-Case - NZXT H510
https://tinyurl.com/y5vquj6g
-EFI folders-
https://tinyurl.com/ybr968w3
Paste EFI folder into EFI partition, reboot and extract one SendMe. Post this dump here for full ACPI solution!
Download RunMe.app Dumper
-DSDT Full Patched Opencore or Clover-
(Request your DSDT in this topic. Read Instructions.
DSDT.MaLd0n GA B460M DS3H.zip
-DSDT Patches-
-FIX ACPI ERRORS
-REMOVE UNUSED SCOPES / DEVICES
-HIGH PRECISION EVENT TIMER
-SATA
-DMAC
-REMOVE PROBLEMATIC AND UNUSED DEVICES
-FIX K.P in REBOOT
-SLPB
-DARWIN / WINDOWS 2015
-XHCI
-PLUGIN TYPE
-HDEF
-REAL TIME CLOCK
-ARTC
-IRQs
-SBUS
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-FWHD
-USBX
-PMCR
-XSPI
-CNVW
-IMEI
-EC
-PNLF
-ARPT
-GFX0
-NVME
-DTGP
-HDMI / HDAU
-Screenshots-
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad and many, many, many others!
  • Like 2
yes
Hi, MaLd0n
I have same MB and i5-10400.
I created USB with Big Sur installer with Clover EFI from 1st post but Clover stuck on scan entries.
Google told me that Clover's build from 1st post had this bug.
I replace BOOTX64.efi with actual file.
But now I stuck at +++++++++
Update: solved by editing config.plist with using OCQuirks
Previously I used OC but now I need to use CLOVER.
Can you give me some advices?
Thank you.
Edited by Volosandro
k ;)
sorry but i still need help
ASUS AMD Radeon RX 5500XT , DUAL-RX5500XT-O8G-EVO, monitor connected with HDMI
I use last Clover r5127, DSDT from this topic and EFI from
I update my Catalina to BigSur, system loaded, but I get black screen insted logon screen.
My Clover config in attachments.
Than you!
UPDATE: sorry again - I found stupid mistake in my config. But now I face that apps installation/update from AppStore never complete and downloading update of BigSur always failed.
config.plist.zip
found mistake in config
u need agdpmod=pikera
12 minutes ago, Volosandro said:
i already use this boot-arg but the problem remains
reset nvram?
Dear Sir @MaLd0n
I'm looking for the EFI for my Gigabyte Aorus B460M Pro (https://www.gigabyte.com/Motherboard/B460M-AORUS-PRO-rev-10#kf),
in which lead me to this post. Thanks so much for your upload.
I plan to try to apply the EFI (Opencore) of GA B460M DS3H to my Gigabyte Aorus B460M Pro.
Looking into the different between those two, i found that it has:
1. Audio. B460M DS3H has Realtek® ALC887 codec and Gigabyte Aorus B460M Pro has  Realtek® ALC1200
- I found in the uploaded kext (for B460M DS3H) has RealtekRTL8111.kext which i guess it won't work with ALC1200 <-- so what i need to do with this?
2. the Network Adapter, B460M Pro has Intel® GbE LAN chip (1000 Mbit/100 Mbit) and B460M DS3H has Realtek® GbE LAN chip (1000 Mbit/100 Mbit)
- I guess to add IntelMausi would help to resolve
3. USB Controller : the different comes from Type C (B460M Pro has) mainly <-- i don't know how to deal with that.
For the details specification between the two, please find the link below.
https://www.gigabyte.com/Comparison/Result/2?pids=7341%2C7328
So please help me which i need & change to adapt the uploaded EFI to my Gigabyte B460M Pro.
Tks sir.
Edited by quan0509
Hey @MaLd0n
Can i use this full patch for only iGPU system (the same spec recommendation but with out rx 5700 xt).
What i need to do to comply this, i guess i can't use the Mac Pro SMBIOS any more, have to change to iMAC20,1 ?
Tks
3 hours ago, quan0509 said:
Hey @MaLd0n
without DGPU use iMac20 smbios
Got the same spec. Is this DSDT Patch work with Big Sur?
Do I need to do anything else to install Big Sur?
4 hours ago, MaLd0n said:
use this folder
https://tinyurl.com/y7puzwv9
after that u just ned full dsdt patched
Tks sir,
I followed ur instructions and got Big Sur success installed. Only one issue is the machine can't wake up after sleep.
I do post my dump here in the link below:
https://www.mediafire.com/file/09qjdonvhqgtbzk/Send_me-iMac.zip/file
Please try to help me the full DSDT patched and find out why the machine doesn't wake up after sleep.
Tks sir
hi mald0n GOD
can not multi boot windows10 your post files. (b460m ds3h dsdt + open core)
windows blue screen  (BSOD: ACPI_BIOS_ERROR),
Clover + dsdt (not working BIGSUR)
Any Idea ?
9 hours ago, quan0509 said:
Tks sir,
Tks sir
I found the way, sir. Just update the newest whatevergreen then it works
use bootkey to boot into windows or opencore inject things
hello sir,
how to use bootkey to boot into windows?
F12
20 hours ago, MaLd0n said:
F12
Sir;
I follow & use your files to build b460 with iGPU but my Hackintosh Pasted Graphic.png.zipdetect the system with CPU core i9 6 cores, but my system is only core i5 - 10600.
By the way, I posted the full dump here, please kindly support to get the full patch
https://www.mediafire.com/file/rd6z1fmejvbe7rs/Send_me_Mac.zip/file
How to revise it to the right spec?
Edited by quan0509
