10 hours ago, MaLd0n said:
Olarila BigSur beta 2 is out. try it
Do we have a restore images for beta 2? I cannot update/install from beta 1
Thanks a lot
installation via usb with opencore
after u can use ur Clover folder for Big Sur in SSD
2 minutes ago, Selim Orhan said:
Can I flash  Beta 2 with Win32 Disk Imager?
yes
47 minutes ago, Julian Fischer said:
What should I do next I want to install BigSur?
read first post
On 7/8/2020 at 2:38 AM, MaLd0n said:
Not working, when I boot with OpenCore it starts in Verbose mode then stops after few seconds on an error that shows the date 2020-07-08 and some numbers, does not boot any further.
Attached is the refi folder and the error reporting
EFI.zip opencore-2020-07-08-183946.txt.zip
Gigabyte Z490 Vision D
i7-11700K RocketLake
Powercolour RX6800XT
MacOS Big Sur
Monterey
this topic is clover
1 hour ago, dudewith said:
Can't go past this..any help will be appreciated
u need configure booter quirks
@MaLd0n that's the problem, i'm a noob..don't know where to start doing that. Any guide?
check correct quirks for ur chipset here
https://opencore.slowgeek.com/
On 7/4/2020 at 3:22 AM, xdevillived666 said:
You need a plist editor. Open the config.plist you have, ctrl+f and paste "KernelAndKextPatches" and the other one , enter the values like that or use clover configurator.
Im trying to do this and cannot understand how to, trying with clover config and whilst editor - can you explain please for dummies
 am battling and getting stuck here, can you please advise of easy way
Screenshot 2020-07-09 at 8.01.01 PM.zip
MacOS Big Sur
Monterey
Any  luck with Intel(R) Xeon(R) CPU E5-2670 v3 with X99 boards
Do we need any patch for com.apple.iokit.IOPCIFamily ?
Are the DMG files the same than the OC post?
I mean, I have downloaded one of them but don't remwnber if was from this thread or from OC thread.
Files are the same and only change the process post duplicate the disk?
plist inside drivers/uefi folder
u need test. if need try with 10.15 patch
is same for all
I think I have missed some step.
This is what I have done so far:
- download DMG
- mount DMG
- unmount destination disk (I will use a external Drive USB connected.
- copy (dd) from image to external USB disk
At this point it is suppose that I need to copy BOOTX64 and CLOVERX64 files, but new EFI disk is complete empty.
I have created both folders and copied files inside respectively.
Should I copy my old EFI folder as well?
After that it is suppose to add boot arguments.  But there is no config.plist file.
Is it not needed?
Should I create a new empty plisr file with the boot arguments?  Or copy my old plist file and edit it?
Edited by Waldus
check premade folder in first post
2 hours ago, neverday said:
@ MaLd0n   Estou usando sua EFI para 100 a 400, Catalina sobe mais rápido com a EFI atual, mas BIG SUR fica com foto? Alguma dica para subir o sistema?
https://imgur.com/a/qHwRKm2
Vc vai ter de alterar a config dos quirks
34 minutes ago, neverday said:
@ MaLd0n encontrei a referencia, https://github.com/ReddestDream/OcQuirks, mas não sei como proceder, pode ajudar?
veja nesse site a correta config pro seu chipset
