Big Sur image DMG link for download on google just reached the download limit´s on both links 1 and 2. Does anybody has another direct link or torrent???
Add dmg to your drive.
Go to your drive and find the dmg file. Right click -> Make a Copy
And download DMG from your copy.
3 hours ago, MaLd0n said:
sata, usb ou vídeo
Eu percebi que o smbios que está pre configurado pra imac e o que eu uso é aquela EFI você fez pro Samsung E30... O certo seria usar o que está lá não?
Thanks for the hint bro!!
9 hours ago, Georgy Pesko said:
the config is not good
first dont use any rename in acpi tab
add only _sta rtc fix
9 hours ago, pcit said:
HI dear
remove all ssdt, use usbinjectall for now with xhci limit port patch
a pasta é preset. vc tem de fazer os ajustes pro seu hardware
Hello, Sorry, I don’t quite understand where to get this _sta rtc fix file? or how to create it? Do I understand correctly that this is due to DSDT?
Hi to all.
Is it possible to start Big Sur on ivy Bridge?
I currently run macOS Catalina with no problem but when I use the new clover bootloader with suggested modification, my system  does not start.
Spec:
ASUS P8H61
i7 3770
intel HD 4000 (injected with IMEI)
Someone can help me, thanks
Hey, so I've discovered, that it is probably some kind of a bug in Big Sur.
If you will clone .dmg to other disk in Catalina, it works fine. But, if you want to do the same thing in Big Sur (to new disk and also put a Big Sur there), it will fail the process and drive will be somehow mirrored. Cloning will be completed fine, but I haven't been able to boot onto new Big Sur for some reason and in disk utility, it had no partition, even if there was 120GB cloned. Weird things.
So I wiped everything clean, installed Catalina on 2nd drive and now I want to install the Big Sur on my SSD, Sadly - I haven't got .dmg anymore due to wipe, could somebody please post me a new link to it? (You can send it via PM, if you're uncomfortable with posting new link.
Thanks a lot, hopefully it will work as expected and I will be all set!
Edit:
Nevermind, link 1 works again!
Edited by Honzis Novák
<dict>
                <key>Comment</key>
                <string>KbeBS-EXT (kuckkuck)</string>
                <key>Count</key>
                <integer>1</integer>
                <key>Disabled</key>
                <false/>
                <key>Find</key>
                <data>
                6NQAAADrBeg=
                </data>
                <key>MaskFind</key>
                <data>
                /wD///////8=
                </data>
                <key>MaskReplace</key>
                <data>
                AAAAAAD///8=
                </data>
                <key>MatchOS</key>
                <string>10.16</string>
                <key>Replace</key>
                <data>
                6NQAAACQkOg=
                </data>
                <key>StartPattern</key>
                <data>
                AQAx/74UAAU=
                </data>
            </dict>
            <dict>
                <key>Comment</key>
                <string>KbeBS-SIP (kuckkuck)</string>
                <key>Count</key>
                <key>Disabled</key>
                <false/>
                <key>Find</key>
                <data>
                6HXmDgCFwA+E+gAAAEmLRQ==
                </data>
                <key>MaskFind</key>
                <data>
                /wAAAP//////AP///////w==
                </data>
                <data>
                AAAAAAAAAP///////wAAAA==
                </data>
                <key>MatchOS</key>
                <key>Replace</key>
                <data>
                6HXmDgCFwJCQkJCQkEmLRQ==
                </data>
                <data>
                AgAAQb8BAADc
                </data>
            </dict>
            <dict>
                <key>Comment</key>
                <string>KbeBS-KxldUnmap (vit9696, kuckkuck)</string>
                <key>Count</key>
                <key>Disabled</key>
                <false/>
                <key>Find</key>
                <data>
                /4A9JZxOAAAPhRcBAABB
                </data>
                <key>MaskFind</key>
                <data>
                ////AAAA/////wD/////
                </data>
                <data>
                AAAAAAAAAAD//wAAAAAA
                </data>
                <key>MatchOS</key>
                <key>Replace</key>
                <data>
                /4A9JZxOAACQ6RcBAABB
                </data>
                <data>
                SI0VKyYlAA==
                </data>
            </dict>
Não encontrei meios para inserir lá no clover KerneltoPatch. Como adicionar?
Placa mãe: Asus P8H67M-EVO - Processador Intel Core I5-2500 3.3 GHz
Memória: Kingston 8 GB - 1333 GHz - Vídeo: ATI RADEON HD 5430 1GB GDDR 3
Teclado e Mouse: USB
HD Samsung 1 TB
many renames in acpi tab. dont need it
13 hours ago, Selim Orhan said:
@MaLd0n  how I can solve this error dude?
apfs_extract_root_hash_and_manifest failed with error: 22
inject device ec and use fix _sta rtc
take one shot with -no_compat_check
:guitar
um TextMate.app
at the moment I get the feeling that after I do RESIZE something breaks in my settings and I get a black screen. Now I deployed the image to disk and until I did RESIZE it booted up without a black screen. can it be?
if work...good
I managed to install Big Sur on my Hackintosh - Msi Mobo H110Pro, i3 with HD Intel 630, using VM Fusion, Can I not clone this onto another hard drive and boot from that while using clover 5119, I boot Catalina, windows 10 and high Sierra from the same desktop with clover.
Gigabyte Z490 Vision D
i7-11700K RocketLake
Powercolour RX6800XT
MacOS Big Sur
Monterey
work good with mod version
https://www.olarila.com/topic/9063-guide-installrestore-bigsur-with-clover/
:guitar
um TextMate.app
I could not fixed. Still same error I got. I'll wait stable version.
Olarila BigSur beta 2 is out. try it
