free1975yuly Posted July 4, 2020 Posted July 4, 2020 1 hour ago, MaLd0n said: post one photo 1 hour ago, MaLd0n said: post one photo IMG_0691.7z 1 hour ago, MaLd0n said: post one photo Unfortunatelly I deleted everything with Windows install, but soon I'll try to install again macOS. The KP was tied with VirtualSMC.kext.
Georgy Pesko Posted July 4, 2020 Posted July 4, 2020 5 hours ago, MaLd0n said: what download? translation error. at the moment, out of more than 100 attempts to start the system, only 5 were successful.
SwalzPro Posted July 4, 2020 Posted July 4, 2020 (edited) @MaLd0n Edited July 4, 2020 by madskill.madskill
Administrators MaLd0n Posted July 4, 2020 Author Administrators Posted July 4, 2020 5 hours ago, mineirinhoadventures said: @MaLd0n Preciso de ajuda para subir o Big Sur com clover, estou tendo problemas no USB vc fez o restore pra um usb? 4 hours ago, free1975yuly said: Unfortunatelly I deleted everything with Windows install, but soon I'll try to install again macOS. The KP was tied with VirtualSMC.kext. sound like a missing ec device 4 hours ago, Georgy Pesko said: translation error. at the moment, out of more than 100 attempts to start the system, only 5 were successful. strange. what ur hardware? 3 hours ago, SwalzPro said: what ur hardware? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pcit Posted July 5, 2020 Posted July 5, 2020 (edited) HI dear, i am trying to boot Bigsur on my skylake system, i did the img restore , i have 2 ssd drives on my laptop, one is internal and the second is connected via cd caddy, the restoring process going fast and fine, my system never boot , there are many errors related to usb , i tried the clover to boot, system halted, while when i connect the ssd to usb holder, it boots well , but it never boot while the ssd is internal, attached is the Runme files, my system is working very well on catalina and i am using OC and clover, waiting any reply or help, thank you, my hardware is dell skylake , hd 520 Send me iMac-Pro 2.zip Edited July 5, 2020 by pcit
Georgy Pesko Posted July 5, 2020 Posted July 5, 2020 (edited) 8 hours ago, MaLd0n said: srange. what ur hardware? Asus P7P55D pro Xeon x3470 Rx5700xt 20gb ram Edited July 5, 2020 by Georgy Pesko
mus68 Posted July 5, 2020 Posted July 5, 2020 On 7/3/2020 at 7:14 AM, nazibhasnain said: Any Torrent link for downloading dmg file ? I m trying download for last couple of days but it gets error after 70-80% and never resume... A torrent link will be highly appreciated... Thank you. Second link is more better!
egdroid Posted July 5, 2020 Posted July 5, 2020 Excuse me, I recently just bought a ssd with a size of 120gb, detected 111gb. If I use this restore method, can it be done? I mean whether the size of this restore will adjust to 111GB? Thank you for your concern.
Honzis Novák Posted July 5, 2020 Posted July 5, 2020 Heyo! First things first - thanks for the guide! I have a problem (probably in understanding what to do). I've clonned the .dmg file to second HDD (doing this on Hackintosh Catalina). It is transfered successfully, but on 6th step when checking Clover setup - I mounted EFI partition of new transfered HDD and there is nothing inside, how could I continue? Am I supposed just to install latest Clover there? Thanks!
SwalzPro Posted July 5, 2020 Posted July 5, 2020 13 hours ago, MaLd0n said: what ur hardware? Model Dell 5559 Laptop Processor 2.59 GHz Dual-Core Intel Core i7 Memory 16 GB 1600 MHz DDR3 Graphics Intel HD Graphics 520 AMD R5 M335 1 TB Toshiba HardDisk 1
Administrators MaLd0n Posted July 5, 2020 Author Administrators Posted July 5, 2020 9 hours ago, pcit said: HI dear first start with good and clean config, remove a bunch of non-sense ssdt and add only two patches rename ecdv to ec and sta rtc, check bellow reboot and extract new sendme 7 hours ago, Georgy Pesko said: Asus P7P55D pro first u need check about ur smbios, use iMac14,2 6 hours ago, mus68 said: Second link is more better! Enjoy! 5 hours ago, egdroid said: I recently just bought a ssd with a size of 120gb, detected 111gb. If I use this restore method, can it be done? I mean whether the size of this restore will adjust to 111GB? Thank you for your concern. i think no take one shot 4 hours ago, Honzis Novák said: Heyo! First things first - thanks for the guide! if ur hardware is uefi dont need install just paste efi folder into efi partition 1 hour ago, SwalzPro said: Model Dell 5559 Laptop a good start is ecdv to ec patch rename and _fix sta rtc 36 minutes ago, moviemakergr said: @MaLd0n u have tried clover on 10Th Gen ? yes. work, but need some tests in some cases 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Georgy Pesko Posted July 5, 2020 Posted July 5, 2020 (edited) 1 hour ago, MaLd0n said: first u need check about ur smbios, use iMac14,2 no, my friend, i have "this version of Mac OS X is not supported on this platform!" Also i have this message when i try use iMac14,2 with bootarg -no_compat_check , the system boots with my smsbios imac16,2, and from 18.3 but out of 100 attempts to start the system, it successfully started only 6 times. Right now I have successfully started the system. but after rebooting, I’m sure I can’t start it again Edited July 5, 2020 by Georgy Pesko
MarceloMustaine Posted July 5, 2020 Posted July 5, 2020 Maldon, com a pasta que você indicou eu consigo encontrar a minha partição, mas fica parado em "still waiting for root device" o que pode ser?
Honzis Novák Posted July 5, 2020 Posted July 5, 2020 OK, thanks for the response! I've successfully managed to boot my second HDD - everything works flawlessly! Audio, 3 monitors, ethernet, iMessages, etc. So I have decided to put it on my main SSD - did everything exactly same. But I can not see an UEFI partition of that SSD suddenly in a boot menu, if I select non-UEFI SSD option it boots into other HDD, where the Windows OS is located. I can see the UEFI partition of a HDD, but not SSD - which are installed exactly as same. Starting to be kinda desperate now in here disk1 is Big Sur HDD - works flawlessly disk4 is new Big Sur SSD - can't see it in a BIOS boot menu the UEFI
Administrators MaLd0n Posted July 5, 2020 Author Administrators Posted July 5, 2020 1 hour ago, Georgy Pesko said: no, my friend, i have "this version of Mac OS X is not supported on this platform!" Also i have this message when i try use iMac14,2 with bootarg -no_compat_check , the system boots with my smsbios imac16,2, and from 18.3 but out of 100 attempts to start the system, it successfully started only 6 times. Right now I have successfully started the system. but after rebooting, I’m sure I can’t start it again use imac16,2 and extract one dump https://www.olarila.com/files/Utils/RunMe.app.ziphttps://www.youtube.com/watch?v=k9wmIfGLe3A 48 minutes ago, MarceloMustaine said: Maldon, com a pasta que você indicou eu consigo encontrar a minha partição, mas fica parado em "still waiting for root device" o que pode ser? sata, usb ou vídeo 44 minutes ago, Honzis Novák said: disk1 is Big Sur HDD - works flawlessly disk4 is new Big Sur SSD - can't see it in a BIOS boot menu the UEFI u paste efi folder into efi partition -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Georgy Pesko Posted July 5, 2020 Posted July 5, 2020 43 minutes ago, MaLd0n said: use imac16,2 and extract one dump https://drive.google.com/file/d/1a2yb06kPgbDcuA6lYVQmFuc6qahdAJmL/view?usp=sharing
Honzis Novák Posted July 5, 2020 Posted July 5, 2020 52 minutes ago, MaLd0n said: use imac16,2 and extract one dump https://www.olarila.com/files/Utils/RunMe.app.ziphttps://www.youtube.com/watch?v=k9wmIfGLe3A sata, usb ou vídeo u paste efi folder into efi partition Yes, Yes I did, i mounted EFI partition and pasted the EFI file that i have on HDD that i have booted on - thanks to your tutorial.
pcit Posted July 5, 2020 Posted July 5, 2020 HI dear, i am trying to boot Bigsur on my skylake system, i did the img restore , i have 2 ssd drives on my laptop, one is internal and the second is connected via cd caddy, the restoring process going fast and fine, my system never boot , there are many errors related to usb , i tried the clover to boot, system halted, while when i connect the ssd to usb holder, it boots well , but it never boot while the ssd is internal, i will post my runme results Thank you @Maldon for your reply, i tried booting as you adviced, same issues, catalina boots well but big sur on the other ssd never boot, still usb power issues, attached is my new runme results waiting your help. thank you Send me iMac-Pro 2.zip
Selim Orhan Posted July 5, 2020 Posted July 5, 2020 Hi. I got this error when I try to boot: apfs_extract_root_hash_and_manifest failed with error: 22 How can I solve this?
