jay3444 Posted October 7, 2020 Posted October 7, 2020 Hi Mald0n I'm trying to fix disk0 but can't can you help me Archive.zip
Administrators MaLd0n Posted October 30, 2020 Author Administrators Posted October 30, 2020 Olarila Big Sur 11.0.1 Vanilla Image https://www.olarila.com/topic/6278-new-vanilla-olarila-images/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bella Bieber Posted October 31, 2020 Posted October 31, 2020 Guys, do you have the beta 2 download link (20A4300b) . It is the version that had worked on me.
Administrators MaLd0n Posted November 1, 2020 Author Administrators Posted November 1, 2020 8 hours ago, Bella Bieber said: Guys, do you have the beta 2 download link (20A4300b) . It is the version that had worked on me. https://drive.google.com/file/d/1o9uLbj_ZEgTnu2aqVxd7BpO-ZZ-wDwhU/view?usp=sharing -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bella Bieber Posted November 1, 2020 Posted November 1, 2020 Hi, can you give mediafire link. Google drive is being annoying with gdyhost. Also, can you post historical beta versions and links
Administrators MaLd0n Posted November 1, 2020 Author Administrators Posted November 1, 2020 10 hours ago, Bella Bieber said: Hi, can you give mediafire link. Google drive is being annoying with gdyhost. Also, can you post historical beta versions and links beta 2 only gdrive -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bella Bieber Posted November 1, 2020 Posted November 1, 2020 Just now, MaLd0n said: beta 2 only gdrive Can you reupload to mediafire? I cannot download. It has problems 2020-11-01_07h51_38.zip
junior_desampa Posted November 14, 2020 Posted November 14, 2020 Coloquei o EFI do catalina no PEN do Big Sur, ele sobe mas fica na tela cinza, com o cursor.. não sai disso. image.zip
VirginLevel69 G Posted November 14, 2020 Posted November 14, 2020 My hackintosh work well with catalina 10.15.6 and clover 5119 I want to upgrade to big sur with clover, what do I need to do?
eaduril Posted November 14, 2020 Posted November 14, 2020 7 hours ago, VirginLevel69 G said: Mi hackintosh funciona bien con catalina 10.15.6 y clover 5119 Quiero actualizar a big sur con clover, ¿qué debo hacer? I am in the same situation ... I have Clover 5122 with Catalina 10.15.7. Everything works perfectly. I want to upgrade to Big Sur or install from scratch ... What should I do?
TBR Posted November 15, 2020 Posted November 15, 2020 4 hours ago, eaduril said: Estoy en la misma situación ... Tengo Clover 5122 con Catalina 10.15.7. Todo funciona a la perfección. Quiero actualizar a Big Sur o instalar desde cero ... ¿Qué debo hacer? Buenas noches. Tenía Catalina 10.15.7, con Clover 5126. Hoy por fin he podido instalar BigSur con la imagen del foro. No había manera de instalar. A los pocos segundos pantalla negra, sin texto, y tenía que parar ordenador. Como lleva opencore 0.6.3, no sabía como añadir agdpmod=pikera, tengo una 5700XT. Cuando lo consigo más de lo mismo. Total que del foro me bajé los ficheros para el chipset de mi placa y con ellos y el agdpmod=pikera, después de cambiar los de la imagen, logré por fin instalar BigSur. No me gusta nada opencore, lo veo una solución tercermundista. No aporta nada y es sumamente complicado. Yo espero a Clover que no creo tarde mucho en tener un bootloader que funcione infinitamente mejor que opencore. Tampoco veo nada nuevo en BigSur, es más de los mismo desde hace muchos años. Tampoco me caso con Windows 10, pero el sistema de Mac, me parece de niños. Saludos y perdonar por el rollo.
eaduril Posted November 15, 2020 Posted November 15, 2020 6 hours ago, TBR said: Buenas noches. Tenía Catalina 10.15.7, con Clover 5126. Hoy por fin he podido instalar BigSur con la imagen del foro. No había manera de instalar. A los pocos segundos pantalla negra, sin texto, y tenía que parar ordenador. Como lleva opencore 0.6.3, no sabía como añadir agdpmod=pikera, tengo una 5700XT. Cuando lo consigo más de lo mismo. Total que del foro me bajé los ficheros para el chipset de mi placa y con ellos y el agdpmod=pikera, después de cambiar los de la imagen, logré por fin instalar BigSur. No me gusta nada opencore, lo veo una solución tercermundista. No aporta nada y es sumamente complicado. Yo espero a Clover que no creo tarde mucho en tener un bootloader que funcione infinitamente mejor que opencore. Tampoco veo nada nuevo en BigSur, es más de los mismo desde hace muchos años. Tampoco me caso con Windows 10, pero el sistema de Mac, me parece de niños. Saludos y perdonar por el rollo. Hello! I imagine you've downloaded the BigSur image and burned it with Banela ... So you just have to install it on top? As if you were to install MacOS from the USB but without erasing the hard drive, right?
TBR Posted November 15, 2020 Posted November 15, 2020 4 hours ago, eaduril said: ¡Hola! Imagino que has descargado la imagen de BigSur y la has quemado con Banela ... ¿Entonces solo tienes que instalarla encima? Como si fueras a instalar MacOS desde el USB pero sin borrar el disco duro, ¿verdad? Buenos días. La he instalado desde cero. Nueva borrando disco ssd. Saludos.
eaduril Posted November 15, 2020 Posted November 15, 2020 9 hours ago, TBR said: Buenos días. La he instalado desde cero. Nueva borrando disco ssd. Saludos. Thank you so much! I’m going to try it tomorrow...
Ferhat Umut Dede Posted November 19, 2020 Posted November 19, 2020 Hi Amd Threadripper 1950x i could not setup with this processor. It freezes on the black screen after a little loading.Opencore use.
Administrators MaLd0n Posted November 20, 2020 Author Administrators Posted November 20, 2020 7 hours ago, Ferhat Umut Dede said: Amd Threadripper 1950x i could not setup with this processor. It freezes on the black screen after a little loading.Opencore use. go to opencore https://www.olarila.com/forum/93-olarila-apps/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
casabero Posted March 7, 2021 Posted March 7, 2021 On 11/19/2020 at 9:45 PM, MaLd0n said: go to opencore https://www.olarila.com/forum/93-olarila-apps/ ¿Tiene usted en la sección "Olarila Vanilla Images" una imagen de bigsur con cloverbootloader por defecto?
Administrators MaLd0n Posted March 7, 2021 Author Administrators Posted March 7, 2021 4 hours ago, casabero said: ¿Tiene usted en la sección "Olarila Vanilla Images" una imagen de bigsur con cloverbootloader por defecto? apenas substitua a pasta EFI https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
casabero Posted March 7, 2021 Posted March 7, 2021 2 hours ago, MaLd0n said: apenas substitua a pasta EFI https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ ok gracias, pero pregunto. ¿Cómo puedo introducir la capeta EFI en un archivo imagen .RAW?
Administrators MaLd0n Posted March 7, 2021 Author Administrators Posted March 7, 2021 7 minutes ago, casabero said: ok gracias, pero pregunto. ¿Cómo puedo introducir la capeta EFI en un archivo imagen .RAW? .raw is .dmg, just rename or burn to usb -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
