Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
EFI Premade folders
https://tinyurl.com/dwrtbp8r
--Opencore Vanilla Guide--
https://tinyurl.com/ycvcnp8h
--Clover Vanilla Guide--
https://tinyurl.com/ydhgntcz
--Full Solution with good fine tune you need post your files, check video and run this app bellow--
Download RunMe.app - https://tinyurl.com/y9562hz7
Let's start
System password is 1234
Work in internal or external HDD/SSD / Don't restore to your Mojave/Catalina macOs SSD
1- Download this .dmg and put in your desktop
Link 1-
Link 2 - https://tinyurl.com/ydxme7jl
Credits: vit9696 and Vandroiy
2- Open terminal and mount .dmg
-Run in terminal-
hdid -nomount "/Users/olarila.com/Desktop/macOS_11.dmg"
*change user*
3- Check disks with diskutil list in terminal
***Pay attention, you need restore partition that has EFI partition and 120gb, check image below***
-Run in terminal-
diskutil list
In my case .dmg mounted is disk5 and my NVME is disk1
*mounted .dmg have 120 gb*
4- Unmount Disk
*Make changes according to the result in the terminal*
-Run in terminal-
diskutil unmountDisk /dev/disk1
5- Restore
Restore from disk5 to disk1
-Run in terminal-
sudo dd if=/dev/disk5 of=/dev/disk1 bs=32m
with ctrl + t you can check progress
Restore is done.
Boot into system and enjoy!
EFI Premade folders
Resize Disk After restore Thanks to Pavo
To resize the physical disk of BigSur when using this method
*Identify the physical disk
diskutil list
*repair the physical disk partition
sudo diskutil repairDisk diskX
*Resize the physical disk container volume
sudo diskutil apfs resizeContainer diskXs2 0
  • Like 5
  • Thanks 1
2 minutes ago, JhoonCollins said:
pra restaurar a imagem no hd tem que deixar ele formatado em apfs já antes de fazer a restauração da imagem pra ele?
não. pode ser GUID/HFS tb
10 minutes ago, muhammadbahaa2001 said:
Do I need to edit on Clover and add patches or something?
if u have a skylake+ hardware...work. test it
  • Thanks 1
Any Torrent link for downloading dmg file ? I m trying download for last couple of days but it gets error after 70-80% and never resume... A torrent link will be highly appreciated... Thank you.
HP Pavillion 14-bf14080tx
Core i5 7200u
8gb Ram 2400ghz
Intel HD 620
256 ssd
High Sierra 10.13.4
@MaLd0n Posso utilizar minha pasta Efi do Clover, já com todos as modificações necessárias para meu laptop, e só atualizar as kexts e os arquivos do Clover para usar o Big Sur? Li que o "Lapic Kernel", está sendo inutilizado, no caso, procede? Ou consigo ainda manter o Kernel habilitado para o Big Sur?
hello, anybody cn help me? i have black screen. also i write in config agdpmod=pikera... and have a black screen =\ tell me where can I read about the solution to my problem?
running :
sudo dd if=/dev/disk5 of=/dev/disk1 bs=32M
outputs:
dd: bs: illegal numeric value
What should I do in this case?
Edit: fixed by using lowercase "m"
Edited by xdevillived666
14 hours ago, MaLd0n said:
d- Go to KernelAndKextPatches tab, KernelToPatch and add these patches / How do I add them? It gives me no options for such list of values .
Quote
<dict>
                <key>Comment</key>
                <string>KbeBS-EXT (kuckkuck)</string>
                <key>Count</key>
                <integer>1</integer>
                <key>Disabled</key>
                <false/>
                <key>Find</key>
                <data>
                6NQAAADrBeg=
                </data>
                <key>MaskFind</key>
                <data>
                /wD///////8=
                </data>
                <key>MaskReplace</key>
                <data>
                AAAAAAD///8=
                </data>
                <key>MatchOS</key>
                <string>10.16</string>
                <key>Replace</key>
                <data>
                6NQAAACQkOg=
                </data>
                <key>StartPattern</key>
                <data>
                AQAx/74UAAU=
                </data>
            </dict>
            <dict>
                <key>Comment</key>
                <string>KbeBS-SIP (kuckkuck)</string>
                <key>Count</key>
                <key>Disabled</key>
                <false/>
                <key>Find</key>
                <data>
                6HXmDgCFwA+E+gAAAEmLRQ==
                </data>
                <key>MaskFind</key>
                <data>
                /wAAAP//////AP///////w==
                </data>
                <data>
                AAAAAAAAAP///////wAAAA==
                </data>
                <key>MatchOS</key>
                <key>Replace</key>
                <data>
                6HXmDgCFwJCQkJCQkEmLRQ==
                </data>
                <data>
                AgAAQb8BAADc
                </data>
            </dict>
            <dict>
                <key>Comment</key>
                <string>KbeBS-KxldUnmap (vit9696, kuckkuck)</string>
                <key>Count</key>
                <key>Disabled</key>
                <false/>
                <key>Find</key>
                <data>
                /4A9JZxOAAAPhRcBAABB
                </data>
                <key>MaskFind</key>
                <data>
                ////AAAA/////wD/////
                </data>
                <data>
                AAAAAAAAAAD//wAAAAAA
                </data>
                <key>MatchOS</key>
                <key>Replace</key>
                <data>
                /4A9JZxOAACQ6RcBAABB
                </data>
                <data>
                SI0VKyYlAA==
                </data>
            </dict>
How do you add those vales? It doesn't give me the option.
Edited by macdoktor
1 minute ago, macdoktor said:
You need a plist editor. Open the config.plist you have, ctrl+f and paste "KernelAndKextPatches" and the other one , enter the values like that or use clover configurator.
  • Like 2
no
tem de criar o patch
csm is disable?
use copy and paste and change only numbers
I’m getting this error
serial atapi device reconfiguration did not complete successfully
apfs_vfsop_sync:3804: disk1: error when flushing data for inode 74420 on volume ‘Test -Data’ - Device not configured(6)
8 hours ago, MaLd0n said:
csm is disable?
Hello, I do not have these settings in my BIOS. I do not have a built-in graphics card. asus p7p55d pro. xeon x3470. out of more than 50 downloads, only 4 were successful.
11 hours ago, MarceloMustaine said:
eu fiz a configuração conforme o seu tutorial MaLd0N mas agora o clover não reconhece minhas partições do mac, o que eu posso ter feito errado?
veja a pasta preset
post one photo
what download?
4 hours ago, Fabien FORTON said:
I clone my Catalina Disk on another Disk . And now I want to update the disk clone into big Sur . Is it possible ?
use a restore way for test
22 minutes ago, free1975yuly said:
I've done all things adviced above by Daniel, and to use qiurcs from opencore instead of AppleMemory fix driver here results KP, no matter what I try!
post one photo
