6 hours ago, MaLd0n said:
u know what ur embedded controller?
what ur notebook?
Notebook Dell Inspiron 5593 i5-1035G1 8GB 512SSD 15.6" MX230 2GB
I extracted these aml files from windows
aml.zip
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
what efi folder u use? send me this folder
7 minutes ago, rositaott said:
from that link
use this folder
http://s000.tinyupload.com/index.php?file_id=70213875618284026209
reset nvram first time
5 minutes ago, MaLd0n said:
Installing now :guitar:guitar:guitar...thank you...so what folder I suppose to download by the way cause I think I've tried every folder for 10th gen and with 400 series
another issue here, can't see my SSD form DiskUtility even show all devices
https://imgur.com/a/yaqmJcM
Big Sur?
2 minutes ago, rositaott said:
Catalina
check bios/uefi, sata mode
1 minute ago, uncletonn said:
ACER NITRO 5 AN515-55-517N cannot boot this EFI
use ec0 to ec rename and sta rtc fix
Quote
no this option in my bios, (secure boot already disabled)
my bios setting
Quote
check if have bios/uefi update
I still can not boot  i5 10300h Comit lake not support?
But i can boot config2 from efi olarila 10.15.6
video is a mistery for now
trackpad need update in voodooi2c, try add dev id inside kext
Hi @MaLd0n, this is what happened when after updating bios, very strange.stil usingte lst EFI you send.
Edited by rositaott
This error is about unsupported smbios ;) change it
Yeah, strange thing is I use the same USB stick with the EFI folder you send from link which normally booted until recovery, then after bios update, already have that error.
use -no_compat_check
Enjoy!
Hi, i have this kernel panic when going to sleep:
panic(cpu 2 caller 0xffffff7f8611c09e): "[IGFB][PANIC][POWER    ] " "Cannot allow DC9 without disallowing DC6\n"@/Library/Caches/com.apple.xbs/Sources/GPUDriversIntel/GPUDriversIntel-14.7.8/IONDRV/ICLLP/AppleIntelFramebuffer/AppleIntelController.cpp:5531
Backtrace (CPU 2), Frame : Return Address
0xffffff810febb970 : 0xffffff800151a65d mach_kernel : _handle_debugger_trap + 0x49d
0xffffff810febb9c0 : 0xffffff8001654a75 mach_kernel : _kdp_i386_trap + 0x155
0xffffff810febba00 : 0xffffff80016465fe mach_kernel : _kernel_trap + 0x4ee
0xffffff810febba50 : 0xffffff80014c0a40 mach_kernel : _return_from_trap + 0xe0
0xffffff810febba70 : 0xffffff8001519d27 mach_kernel : _DebuggerTrapWithState + 0x17
0xffffff810febbb70 : 0xffffff800151a117 mach_kernel : _panic_trap_to_debugger + 0x227
0xffffff810febbbc0 : 0xffffff8001cc1abc mach_kernel : _panic + 0x54
0xffffff810febbc30 : 0xffffff7f8611c09e com.apple.driver.AppleIntelICLLPGraphicsFramebuffer : __ZN31AppleIntelFramebufferController11enableHWDC6Ev.cold.1
0xffffff810febbc40 : 0xffffff7f860cb635 com.apple.driver.AppleIntelICLLPGraphicsFramebuffer : __ZN31AppleIntelFramebufferController9enableDC9Ev + 0x3b
0xffffff810febbc60 : 0xffffff7f860cb531 com.apple.driver.AppleIntelICLLPGraphicsFramebuffer : __ZN31AppleIntelFramebufferController10setDCStateEb + 0x361
0xffffff810febbca0 : 0xffffff7f8609b0e2 com.apple.driver.AppleIntelICLLPGraphicsFramebuffer : __ZN21AppleIntelFramebuffer24setFramebufferPowerStateEj + 0x224
0xffffff810febbcd0 : 0xffffff7f860b0b9f com.apple.driver.AppleIntelICLLPGraphicsFramebuffer : __ZN21AppleIntelFramebuffer12setAttributeEjm + 0x1ad
0xffffff810febbd20 : 0xffffff7f860b0c6a com.apple.driver.AppleIntelICLLPGraphicsFramebuffer : __ZN21AppleIntelFramebuffer12setAttributeEjm + 0x278
0xffffff810febbd70 : 0xffffff7f85f47faa com.apple.iokit.IOGraphicsFamily : __ZN13IOFramebuffer14checkPowerWorkEj + 0x280
0xffffff810febbe10 : 0xffffff7f85f47d08 com.apple.iokit.IOGraphicsFamily : __ZN14IOFBController14checkPowerWorkEj + 0x9a
0xffffff810febbe40 : 0xffffff7f85f4eaeb com.apple.iokit.IOGraphicsFamily : __ZN13IOFramebuffer10systemWorkEP8OSObjectP22IOInterruptEventSourcei + 0x123
0xffffff810febbee0 : 0xffffff8001c2d54d mach_kernel : __ZN22IOInterruptEventSource12checkForWorkEv + 0x17d
0xffffff810febbf30 : 0xffffff8001c2be1e mach_kernel : __ZN10IOWorkLoop15runEventSourcesEv + 0x11e
0xffffff810febbf70 : 0xffffff8001c2b416 mach_kernel : __ZN10IOWorkLoop10threadMainEv + 0x36
0xffffff810febbfa0 : 0xffffff80014c013e mach_kernel : _call_continuation + 0x2e
      Kernel Extensions in backtrace:
         com.apple.iokit.IOGraphicsFamily(576.1)[92A3DAC1-1745-37AC-88DE-FA87B5EB2526]@0xffffff7f85f3d000->0xffffff7f85f8dfff
            dependency: com.apple.iokit.IOPCIFamily(2.9)[DF219CC1-366A-31FC-B8ED-17C584BA2549]@0xffffff7f81f12000
         com.apple.driver.AppleIntelICLLPGraphicsFramebuffer(14.0.7)[18868C3D-C807-3435-BBD6-D95A2F4D2FA7]@0xffffff7f86084000->0xffffff7f86321fff
            dependency: com.apple.iokit.IOACPIFamily(1.4)[68557A36-4EE1-372A-983B-BB2769FDB8E0]@0xffffff7f81f09000
            dependency: com.apple.iokit.IOAcceleratorFamily2(438.7.3)[9D052246-9911-3EB3-89E9-BDF771949C45]@0xffffff7f85fb6000
            dependency: com.apple.iokit.IOReportFamily(47)[8F7948CF-5C25-33F4-A687-67F8A5B7906E]@0xffffff7f81e49000
            dependency: com.apple.AppleGraphicsDeviceControl(5.2.6)[372B091D-3A52-3749-AE17-E8A5103D8DB0]@0xffffff7f8607a000
            dependency: com.apple.iokit.IOGraphicsFamily(576.1)[92A3DAC1-1745-37AC-88DE-FA87B5EB2526]@0xffffff7f85f3d000
BSD process name corresponding to current thread: kernel_task
Boot args: debug=0x100 keepsyms=1 chunklist-security-epoch=0 -chunklist-no-rev2-dev
Mac OS version:
19G2021
Kernel version:
Darwin Kernel Version 19.6.0: Thu Jun 18 20:49:00 PDT 2020; root:xnu-6153.141.1~1/RELEASE_X86_64
Kernel UUID: 1D3A0F3D-D908-397B-BD16-8F48C0823A2E
Kernel slide:     0x0000000001200000
Kernel text base: 0xffffff8001400000
__HIB  text base: 0xffffff8001300000
System model name: MacBookPro16,2 (Mac-5F9802EFE386AA28)
System shutdown begun: NO
Panic diags file available: YES (0x0)
System uptime in nanoseconds: 486125505360
I saw that DC9 and DC6 are two states where the display goes when it goes to sleep... But i don't know what could be the problem...
My Desktop: CPU: i7-7700K, MOBO: Asus Strix Z270F, GPU: Powercolor RX5700, RAM: 16GB 3200mhz
Laptop: Model: Asus S512J-EJ051T CPU: i7-1065g7 GPU: Intel g7 / Nvidia MX330 RAM: 8GB 2666mhz
