tushark2 Posted December 19, 2019 Share Posted December 19, 2019 hi, I was using Nitesh Sierra 10.12.6 and I wanted to clean install new OS high Sierra or Mojave. I tried installing Olarila high Sierra but I was unable to do it but now I managed to install Olarila Mojave 10.14.6 My System: Laptop Dell vostro 3500 series intel i3 m380 2.53 GHz 6Gb ddr3 ram 1st gen intel HD graphics Broadcom BCM43xx there are few things that are not working, I need help for that. 1.sound 2.hd graphics there a problem when booting into Mojave some APCI error that's why it take about 2 min to boot. Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 19, 2019 Administrators Share Posted December 19, 2019 [ref]tushark2[/ref], https://Olarila.com/forum/viewtopic.php?t=9574 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
tushark2 Posted December 19, 2019 Author Share Posted December 19, 2019 [ref]tushark2[/ref], https://Olarila.com/forum/viewtopic.php?t=9574 Thanks for the reply. Ill do the steps and will reply you with the results Link to comment Share on other sites More sharing options...
tushark2 Posted December 20, 2019 Author Share Posted December 20, 2019 [ref]tushark2[/ref], https://Olarila.com/forum/viewtopic.php?t=9574 Hello MaLd0n, I manage to install 1st gen intel HD graphics on Mojave 10.14.6. but this works on only safe mode ..if I normal boot Mojave there is only white screen and I can't do anything. and also can't mount EFI partition as it only boots in safe mode. Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 20, 2019 Administrators Share Posted December 20, 2019 [ref]tushark2[/ref], update clover, kexts and rebuild all -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
tushark2 Posted December 22, 2019 Author Share Posted December 22, 2019 [ref]tushark2[/ref], update clover, kexts and rebuild all hello MaLd0n, I have updated all the kexts and clover to latest version version.I have also modified config.plist. 1st. Whats working. a:wifi works out of the box. b:sound sometime works sometime doesn’t . c: ethernet working properly fine with RealtekRTL8111.kext in efi/k/other.(Realtek RTL8168D/8111D) d:camera is working fine. e:trackpad and two finger swipe WORKING the only problem is intel HD graphics.i followed the guide that you mentioned in previous post but am stuck on white screen before the osx loading screen .I also used my Sierra intel hd graphics kext from /s/l/e :apppleintelgrahpicsFB.it was working fine on Sierra but not in Mojave .. again stuck on white screen.( works fine in safe mode) I did try Mac optimiser to reset nvram and rebuild cashes but that also didn't help some pics for info: can you help me with the problem thx. Link to comment Share on other sites More sharing options...
tushark2 Posted December 22, 2019 Author Share Posted December 22, 2019 hello MaLd0n, I have updated all the kexts and clover to latest version version.I have also modified config.plist. 1st. Whats working. a:wifi works out of the box. b:sound sometime works sometime doesn’t . c: ethernet working properly fine with RealtekRTL8111.kext in efi/k/other.(Realtek RTL8168D/8111D) d:camera is working fine. e:trackpad and two finger swipe WORKING the only problem is intel HD graphics.i followed the guide that you mentioned in previous post but am stuck on white screen before the osx loading screen .I also used my Sierra intel hd graphics kext from /s/l/e :apppleintelgrahpicsFB.it was working fine on Sierra but not in Mojave .. again stuck on white screen.( works fine in safe mode) I did try Mac optimiser to reset nvram and rebuild cashes but that also didn't help some pics for info: can you help me with the problem thx. installed applealc and applehda to /l/e and changed inject audio to 11. Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 22, 2019 Administrators Share Posted December 22, 2019 [ref]tushark2[/ref], use all hackintosh kexts in clover/kexts/other, check Olarila folder for correct and clean way https://Olarila.com/forum/viewtopic.php?f=28&t=8222 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
tushark2 Posted December 30, 2019 Author Share Posted December 30, 2019 viewtopic.php?f=28&t=8222 hello MaLd0n, I have read around 100 post about 1st gen hd graphics on Mojave in past few days and unable to do so. some says you have to patch iographics etc. I have tried all these methods but it fails. I don't know how to make DSDT for my current system also am sure the intel hd graphics am using is working fine on Sierra 10.12.6. but these when am using these kexts on Mojave, it stuck on white screen. I updated all kexts in /clover and /l/e, everything else is working fine : all usb,camera,wifi,touchpad,sound but the only problem is this hd graphics. please help me with this. have also made sendme file from /files/runme ill upload the files you need to help me. thx Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 30, 2019 Administrators Share Posted December 30, 2019 [ref]tushark2[/ref], need check it. i dont have this hardware for test -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
tushark2 Posted December 31, 2019 Author Share Posted December 31, 2019 [ref]tushark2[/ref], need check it. i dont have this hardware for test hello MaLd0n, thx for the reply am posting the pervious DSDT,origin files and my current EFI. please take a look and you can give me some suggestions, what to do. Send me Tushars-MacBook-Pro.zip sierra dsdt origin.zip Link to comment Share on other sites More sharing options...
tushark2 Posted December 31, 2019 Author Share Posted December 31, 2019 hello MaLd0n, thx for the reply am posting the pervious DSDT,origin files and my current EFI. please take a look and you can give me some suggestions, what to do. Current Mojave 10.14.6 Clover folder attached CLOVER.zip Link to comment Share on other sites More sharing options...
tushark2 Posted January 1, 2020 Author Share Posted January 1, 2020 [ref]tushark2[/ref], need check it. i dont have this hardware for test Happy new year, have a great year ahead . TC Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted January 2, 2020 Administrators Share Posted January 2, 2020 [ref]tushark2[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
tushark2 Posted January 2, 2020 Author Share Posted January 2, 2020 [ref]tushark2[/ref], DSDT.aml.zip thank you for fast reply .. I have copied the above file in /efi/clover/ACPI/patached now the only problem is intel HD graphics please give me suggestion if you think I have to do something else in this system. Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted January 2, 2020 Administrators Share Posted January 2, 2020 [ref]tushark2[/ref], need check, i don't have ur hardware for test -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
tushark2 Posted January 3, 2020 Author Share Posted January 3, 2020 [ref]tushark2[/ref], need check, i don't have ur hardware for test Hello MaLd0n, thx for the help, I manage to fix 1st gen intel HD graphics on Mojave 10.14.6 I found two new problems that I want to discuss with you:- 1. I can't use my mic.speaker is working fine. 2.my wifi card support airdrop and am unable to use it. it doesn’t show any airdrop devices. Link to comment Share on other sites More sharing options...
