Esfera Posted November 8, 2019 Posted November 8, 2019 Instalei o High sierra e tras a instalacion arranquei dende o Clover para arrancar por primeria vez e dame un erro, poño aquí as imaxes: https://imgbox.es/image/L4CbK / https://imgbox.es/image/L4y1D Tras isto, noutro hilo MaLd0n comentoume que tiña que usar isto, a pasta pro chipset 9: viewtopic.php?f=28&t=8222 Eu descarguie mais non sei que face con ela xa que e a primeira vez que trato cun hackintos. Se algen me pode axudar agradezcoo moito.
Administrators MaLd0n Posted November 8, 2019 Administrators Posted November 8, 2019 [ref]Esfera[/ref], use nv_disable=1 and install nvidia web driver -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Esfera Posted November 8, 2019 Author Posted November 8, 2019 onde poño iso ou como uso o comando? o problema que teño e que non chego ao desktop... no podo acceder nin a consola...logo non sei como facer
Administrators MaLd0n Posted November 8, 2019 Administrators Posted November 8, 2019 [ref]Esfera[/ref], press barspace in clover boot screen -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Esfera Posted November 8, 2019 Author Posted November 8, 2019 OK i press barspace, put command: nv_disable=1 and try. Ty for all, i post later if run or not same ty for your help, if work i donate sure ^^
Esfera Posted November 8, 2019 Author Posted November 8, 2019 OK i try and go to signed prohibited and dont run Second Try: work but when i restart and use Verbose and nvidia -1 go same to prohibited signed I dont know try, i read and read the forum but dont found solution for me case...
