hello,
already bravo, here there is apparently information and very important tools to install as it should be OSX on a PC
I have a problem my card is a rev-UD7 GA67A 1.0 or F8 bios F7A with update
there are DSDT card GAP67-UD4 bios rev B3 F4 and F5 and other DSDT P67 chipset but not my card.
How can I do to have a DSDT for my motherboard
is what your little windows utility DSDTeditor DSDT make a right?
since apparently he's saying makes a DSDT Bios depending on when this is sour .. Windows, I'm running Windows 7 64-bit
Your tool looks complicated to use and I have no programming knowledge or too little
There are many support my motherboard with kakewalk 4.1.1 but you must already have installed MAC OS X to use this application. The cat bites its tail and was very poorly
How can I do to install OSX 10.6.8 or version 10.7.1 or version 10.7.2
on my PC
I am willing to buy OSX 10.7.2 Lion to be quiet if it is necessary or version 10.6.x
but the procedures gives information when we are already in MACOSX86 for the LION mide a day ect ...
If possible I would like abortion as the two systems on my machine to BOOT
thank you very much for your help
and viva Brazilia
I am a french man with a bad english language sorry
@didman78
yes it works well
or
use linux live cd(ubuntu 10.10)and runing in terminal:
sudo cat /proc/acpi/dsdt > dsdt.aml
or
or use the windows application "Everest" also does the job
http://Olarila.com/forum/viewtopic.php?f=19&t=131&start=10
after you extract it, you need Copiler and patch, use the dsdt editor
http://Olarila.com/forum/viewtopic.php?f=19&t=62
on my PC
the several ways you have to choose the one that best suit you.
http://Olarila.com/forum/viewforum.php?f=3
I think so
OS X Mavericks 10 .9.3 - OS X Mountain Lion 10.8.5 - Kali Linux 1.0.6
thanks you very much for tou response,
on two proposals that you made ​​me
- Used to compile the file Unbutu AML
- Windows users application "Everest"
it is the solution that gives a result almost perfect
in the integrity of the file ms OSX
thank you
