aelsharawi Posted December 11, 2011 Posted December 11, 2011 i successfully edited dsdt for the card and its HDMI audi,but i need more help extracting the registry info from io registry of original 1TI 5670 card from original imac http://pastebin.com/Cf1di2Vz the above is the code it contains the bin image , frame buffer I hope someone help me transfer this code to my DSDT my current DSDT EDIT: Device (GFX0) { Name (_ADR, Zero) Name (_PRW, Package (0x02) { 0x09, 0x05 }) Method (_DSM, 4, NotSerialized) { Store (Package (0x0C) { "@0,name", Buffer (0x0D) { "ATY,Vervet" }, "@1,name", Buffer (0x0D) { "ATY,Vervet" }, "@2,name", Buffer (0x0D) { "ATY,Vervet" }, "@3,name", Buffer (0x0D) { "ATY,Vervet" }, "model", Buffer (0x13) { "ATI Radeon HD 5670" }, "hda-gfx", Buffer (0x0A) { "onboard-1" } }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } } Device (HDAU) { Name (_ADR, One) Method (_DSM, 4, NotSerialized) { Store (Package (0x02) { "hda-gfx", Buffer (0x0A) { "onboard-1" } }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } } Method (_STA, 0, NotSerialized) { Return (0x0F) } Name (PE00, Package (0x04) { Package (0x04) { 0xFFFF, Zero, LNKA, Zero }, Package (0x04) { 0xFFFF, One, LNKB, Zero }, Package (0x04) { 0xFFFF, 0x02, LNKC, Zero }, Package (0x04) { 0xFFFF, 0x03, LNKD, Zero } }) Name (AE00, Package (0x04) { Package (0x04) { 0xFFFF, Zero, Zero, 0x10 }, Package (0x04) { 0xFFFF, One, Zero, 0x11 }, Package (0x04) { 0xFFFF, 0x02, Zero, 0x12 }, Package (0x04) { 0xFFFF, 0x03, Zero, 0x13 } }) Method (_PRT, 0, NotSerialized) { If (LNot (PICF)) { Return (PE00) } Else { Return (AE00) } } } I also need to remove the 3 vervet devices port to be only one port ,how ??? thx in advance
charlesjavier Posted August 1, 2012 Posted August 1, 2012 Is it my card Saphire HD 5870 1GB Device (PEGP) { Name (_ADR, 0x00010000) Device (GFX0) { Name (_ADR, Zero) Name (_PRW, Package (0x02) { 0x09, 0x05 }) OperationRegion (PEGH, PCI_Config, Zero, 0x40) Field (PEGH, ByteAcc, NoLock, Preserve) { VID0, 16, DID0, 16 } Method (_DSM, 4, NotSerialized) { If (LEqual (Arg0, Buffer (0x10) { /* 0000 */ 0xC6, 0xB7, 0xB5, 0xA0, 0x18, 0x13, 0x1C, 0x44, /* 0008 */ 0xB0, 0xC9, 0xFE, 0x69, 0x5E, 0xAF, 0x94, 0x9B })) { If (LNotEqual (And (VID0, 0xFFFF), 0xFFFF)) { Store (Package (0x5C) { "@0,AAPL,boot-display", Buffer (0x04) { 0x01, 0x00, 0x00, 0x00 }, "@0,compatible", Buffer (0x0B) { "ATY,Uakari" }, "@0,connector-type", Buffer (0x04) { 0x00, 0x04, 0x00, 0x00 }, "@0,device_type", Buffer (0x08) { "display" }, "@0,display-type", Buffer (0x05) { "NONE" }, "@0,name", Buffer (0x0B) { "ATY,Uakari" }, "@0,VRAM,memsize", Buffer (0x08) { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40 }, "@1,compatible", Buffer (0x0B) { "ATY,Uakari" }, "@1,connector-type", Buffer (0x04) { 0x04, 0x00, 0x00, 0x00 }, "@1,device_type", Buffer (0x08) { "display" }, "@1,display-type", Buffer (0x05) { "NONE" }, "@1,name", Buffer (0x0B) { "ATY,Uakari" }, "@2,compatible", Buffer (0x0B) { "ATY,Uakari" }, "@2,connector-type", Buffer (0x04) { 0x04, 0x00, 0x00, 0x00 }, "@2,device_type", Buffer (0x08) { "display" }, "@2,display-type", Buffer (0x05) { "NONE" }, "@2,name", Buffer (0x0B) { "ATY,Uakari" }, "AAPL,EMC-Display-List", Buffer (0x40) { /* 0000 */ 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0008 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0010 */ 0x06, 0x10, 0x00, 0x00, 0x1B, 0x92, 0x00, 0x00, /* 0018 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0020 */ 0x06, 0x10, 0x00, 0x00, 0x1C, 0x92, 0x00, 0x00, /* 0028 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0030 */ 0x06, 0x10, 0x00, 0x00, 0x21, 0x92, 0x00, 0x00, /* 0038 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, "AAPL,aux-power-connected", Buffer (0x04) { 0x01, 0x00, 0x00, 0x00 }, "AAPL,backlight-control", Buffer (0x04) { 0x00, 0x00, 0x00, 0x00 }, "AAPL,overwrite_binimage", Buffer (One) { 0x01 }, "AAPL,slot-name", Buffer (0x09) { "PCIe x16" }, "AAPL00,blackscreen-preferences", Buffer (0x04) { 0x00, 0x00, 0x00, 0x08 }, "AAPL01,Coherency", Buffer (0x04) { 0x02, 0x00, 0x00, 0x00 }, "AAPL01,blackscreen-preferences", Buffer (0x04) { 0x00, 0x00, 0x00, 0x08 }, "ATY,Card#", Buffer (0x0E) { "109-B87101-00" }, "ATY,Copyright", Buffer (0x33) { "Copyright AMD Inc. All Rights Reserved. 2005-2012" }, "ATY,EFICompileDate", Buffer (0x0C) { "Aug 31 2010" }, "ATY,EFIDispConfig", Buffer (0x08) { 0x0D, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, "ATY,EFIDriverType", Buffer (One) { 0x02 }, "ATY,EFIEnabledMode", Buffer (One) { 0x02 }, "ATY,EFIHWInitStatus", Buffer (0x08) { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, "ATY,EFIOrientation", Buffer (0x02) { 0x00, 0x01 }, "ATY,EFIVersion", Buffer (0x17) { "012.020.000.001.036486" }, "ATY,EFIVersionB", Buffer (0x0F) { "113-B87101-012" }, "ATY,EFIVersionE", Buffer (0x0F) { "113-B8710A-318" }, "ATY,MCLK", Buffer (0x04) { 0xC0, 0xD4, 0x01, 0x00 }, "ATY,MemRevisionID", Buffer (0x02) { 0x03, 0x00 }, "ATY,MemVendorID", Buffer (0x02) { 0x02, 0x00 }, "ATY,PlatformInfo", Buffer (0x80) { /* 0000 */ 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0008 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0010 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0018 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0020 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0028 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0030 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0038 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0040 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0048 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0050 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0058 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0060 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0068 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0070 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0078 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, "ATY,Rom#", Buffer (0x0F) { "113-C00140-S5B" }, "ATY,SCLK", Buffer (0x04) { 0x28, 0xDB, 0x0B, 0x00 }, "ATY,VendorID", Buffer (0x02) { 0x02, 0x10 }, "device_type", Buffer (0x11) { "ATY,UakariParent" }, "model", Buffer (0x1A) { "ATI Radeon HD 5870 Series" }, "name", Buffer (0x11) { "ATY,UakariParent" } }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } } Return (0x80000002) } } Device (HDAU) { Name (_ADR, One) Method (_DSM, 4, NotSerialized) { Store (Package (0x02) { "hda-gfx", Buffer (0x0A) { "onboard-1" } }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } } }
