So I managed to get your installer to work on the newest version of unRAID, I Used the X99 Clover files and the install rolled smooth no modifications needed only needed to set bios resolution to 1920x1080 so that the bios wouldn't adjust the monitor to 4k. So far tho seems very quick and responsive Nvidia is working out the box. Would you mind providing a DSDT please good sir?
here is the the send me for some weird reason it wouldn't let me attach to the first message.
very bug DSDT, missing many devices
believe it or not osx seems to be running great! lol I haven't tried to login to iTunes or iMessage or anything yet but for running on 8 cores with 8gb of ram its snappy
do you have any suggestions on kext or drivers I should load into clover by any chance?
use dpci manager and check all ur hardware
