rev4turbomonster Posted January 15, 2019 Posted January 15, 2019 Hi There, Sorry if this is in the wrong place I have just finished putting together my z390 build spec is Asus Prime z390-A I9 9900k 32gb DDR4 3000MHZ ram Samsung 970 NVME 500gb with MacOS on 500Gb SSD with windows 10 AMD RX570 8GB Sapphire card The machine is booting perfectly I just need to add themes etc when everything is stable. I can get into App Store iCloud iMessage and FaceTime so think everything is set up perfectly there. I need to sort Audio it is a 1220 chipset but I don't know what I need to do if someone could help and also sleep. When I send the machine to sleep it instantly wakes just as the fans stop spinning wake for access is off as is power nap could really do with this functionality if someone could help me sort it please. Thanks in advance Matt
Administrators MaLd0n Posted January 15, 2019 Administrators Posted January 15, 2019 [ref]rev4turbomonster[/ref], RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
rev4turbomonster Posted January 15, 2019 Author Posted January 15, 2019 thanks for your help Send me Matts-iMac.zip
Administrators MaLd0n Posted January 15, 2019 Administrators Posted January 15, 2019 [ref]rev4turbomonster[/ref], DSDT.aml.zip audio, inject via clover -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
rev4turbomonster Posted January 15, 2019 Author Posted January 15, 2019 Hi Maldon you made me a DSDT on the DSDT thread is this different to try and sort sleep. Thanks for your help
rev4turbomonster Posted January 15, 2019 Author Posted January 15, 2019 Maldon you are a star working perfectly on payday I will send you some beer tokens Thanks
Administrators MaLd0n Posted January 15, 2019 Administrators Posted January 15, 2019 [ref]rev4turbomonster[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
GranRafaEstudio Posted February 7, 2019 Posted February 7, 2019 ¿Whats is the correct folder of Olarila for chipset Z390? Thank Maldon
erroruser Posted February 7, 2019 Posted February 7, 2019 GranRafaEstudio, this one https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
yumo Posted February 20, 2019 Posted February 20, 2019 GranRafaEstudio, this one https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip Hello Olarila for chipset Z390 has VoodooTSCSync.kext. Is VoodooTSCSync.kext necessary for Z390 + 9900k?
Administrators MaLd0n Posted February 20, 2019 Administrators Posted February 20, 2019 [ref]yumo[/ref], don't need, i'll update clover folder today -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
yumo Posted February 20, 2019 Posted February 20, 2019 [ref]yumo[/ref], don't need, i'll update clover folder today Thank you, MaLd 0n. I am looking forward to it.
yumo Posted February 22, 2019 Posted February 22, 2019 [ref]yumo[/ref], don't need, i'll update clover folder today Hi,MaLd0n Where can I get updated Clover folders?
Administrators MaLd0n Posted February 22, 2019 Administrators Posted February 22, 2019 [ref]yumo[/ref], no time now, i'll try today -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
yumo Posted February 22, 2019 Posted February 22, 2019 [ref]yumo[/ref], no time now, i'll try today Thank you. Now I have no problem so I am not in a hurry. I found your Clover folder in another thread. It is very good to learn. I could see four big changes. 1, NvmExpressDxe - 64.efi was added. 2, RTCMemoryFixup.kext was added as Apple RTC check in Config.plist is off. 3, Disable panic kext logging on 10.14 Release kernel patch was added. 4, SMBIOS changed from imac 18, x to imacpro 1, 1. I think I will try it when I have time.
