please help. I am desperate. error dsdt editor :(
Hi guys..
Great forum, hope you can help me.
I have wasted 3 weeks trying to get my hackintosh to work :oops::oops:
my system is
asus p8h67-m pro
i5 2500k
8gb ram
using the hd3000 intel graphics from the 2500k
sata hdd with windows set to ahci
external usb hdd with 2 partitions, 1 xmove lion installer, 1 lion partition (and the mac efi partition of course)
I am now trying to get it all working by using a custom dsdt but i have failed very badly so far :oops:
After i extract dsdt using the editor, i then apply the p8h67 m pro.txt patch from the pack page on Olarila. I then try to compile but when i click on fix errors, i always remain with 2 errors:
line 1591 Min/max/length/gran are all zero but no resource tag
1622 same error.
here is my extracted unedited dsdt that i extracted using editor
I installed a clean copy of lion and booted using rBoot from tonycrap, i only installed realtek network next to come here, and nothing else, no easy beast, no userdsdt, nothing yet. I am trying to install a userdsdt with a custom dsdt for my system because i can't get anything else to work!
Can anyone please help me? this is killing me :oops::oops:
thanks in advance
dsdt.aml.zip
Please download DSDT Editor again, it was a bug, but it was fixed.
The fix is: length = max - min + 1 (just set length as 1, since max and min are 0).
Thanks for the response! You were right, i managed to save dsdt now!
however now i have new problems :(
I'm not sure how to fix, my board has alc892 audio, and i think that is my new problem. I installed audioHDA rollback (only the rollback, i didn't install any other audio kext)
i have attached my latest kernel panic and the patched dsdt
thank you again for your help already, i hope someone out there can help me with this new problem. I feel like a zombie for 3 weeks!
Only AppleHDA rollback won't work, you need a LegacyHDA or a patched AppleHDA, and an HDEF patch in DSDT (or HDAEnabler).
You can also try VoodooHDA http://Olarila.com/forum/viewtopic.php?f=18&t=454
There's no KP in the attached image.
thank you very much for your help, i understand all of this more now :D :D
I am going to try those fixes for the hda, but i also noticed something more in the -v.
i notice that there is errors about c-states and p-states, it says they were not loaded even though i have GenerateCStatesYesGeneratePStatesYes in the boot plist. You said there was no kernel panic in the image, but my pc stays frozen at that image for a long time so i think it is stuck, could it be the p-states problem that is stopping the pc?
thanks again
Hi, thanks for again for the help :)
Unforunately it still doesn't want to work! I deleted the dsdt.aml in the extra folder, then loaded lion using rBoot, so i extracted the dsdt again, applied p8h67-mpro patch, from misc patches -> hdef, duallink, new hpet, lpc and from desktop patches -> dtgp, smbus, irqs, rtc.
I then compiled and fixed errors (0 errors), then saved it it as dsdt.aml into the extra folder. I also edited the info.plist from applehda and changed the layoutID to 12 (it was 8) as the hdef patch had 0xc value, i then repaired permissions and kext cache using kext wizard.
And now in -v i am getting still waiting for root device. Would you know what has happened? It even happens in -x -v mode too. I also always still get the "acpi cpus table not found p-states not generated" same for c-states
Before when i only applied p8h67-m pro patch i could get into lion using -x mode, so it must be something new i did!
Do i need to run repair permissions every time i delete the dsdt.aml file and put a new one in the extra folder?
Is this meant to be this difficult haha? :oops:
p.s i have already patched the cpupowermanagement kext with speedstepper also
Update: I did a rollback HDA in multishit, and now it loads again without any flags and using a new custom edited dsdt using p8ph67 patch, duallink patch, irq, hdef and dtgp! woo hoo progress!
however, the system doesn't have any sound (still have those efi rom hda-gfx errors in -v) and the intel hd3000 graphics card isn't recognised (chipset model: unknown, no kext loaded)
I installed HDEF patch so i can't use voodoo hda, i have a feeling i have to patch the applehda.kext some how? i have alc8xx kext but when i checked the kext loaded with kext wizard, it is not loaded, only applehda and applehdacontroller are loaded. My applehda has a layoutid of 8, and i think it should be 12 (rollback mustve reverted it back to 8?), should i be playing around with that to patch it?
And I have installed macmini 5,1 smbios because apparently that is what you need for intel hd3000 to be recognized, but it isn't working =/ any ideas on that one?
thanks very much again my friend. this has been one of the most frustrating things i have ever done with a computer! :lol:
If you apply the p8h67-m pro "pack" you don't need to apply the "misc" patches (except DualLink).
There's no need to update cache after replacing DSDT. I don't know what Kext Wizard does in Lion, but a "sudo touch /System/Library/Extensions" is enough to rebuild kernelcache.
I have no idea about patching AppleHDA, I use VoodooHDA.
Need expert help with your Hackintosh?
Get professional Olarila support for:
Support us - Donate HERE
