foliasis Posted December 28, 2018 Posted December 28, 2018 Hi me again. So I have got almost everything working on my Dell Vostro 3558 with Mojave 10.14.1 Lastly what remains is the SD Card. (Realtek USB 2.0 CRW). It is shown in System Report but the card is not mounted. What I tried- 1. AnySDCard.kext (changing the id everything) 2. CustomPeripheralDevice.kext 3. AppleStorageDrivers.kext (edited the ids as stated in the thread) None of them seem to work. Any help will be appreciated
Administrators MaLd0n Posted December 28, 2018 Administrators Posted December 28, 2018 [ref]foliasis[/ref], RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
foliasis Posted December 30, 2018 Author Posted December 30, 2018 [ref]foliasis[/ref], RunMe.app Here is the zipSend me MacBook-Air.zip
Administrators MaLd0n Posted December 30, 2018 Administrators Posted December 30, 2018 [ref]foliasis[/ref], dont load, u need check what device card read stay DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
foliasis Posted December 30, 2018 Author Posted December 30, 2018 [ref]foliasis[/ref], dont load, u need check what device card read stay DSDT.aml.zip It still stays the same ioreg attached MacBook Air.zip
erroruser Posted December 30, 2018 Posted December 30, 2018 [ref]foliasis[/ref], sd card shows in ioreg an loaded try mac book pro smbios to test AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
foliasis Posted December 30, 2018 Author Posted December 30, 2018 but it doesn't mount it shows without any change in kexts also If I use AnyCardReader.kext it is identified as Apple Internal Card but does not mount on inserting the sd card Added in 7 minutes 51 seconds: Another thing that i have observed is that of I plug in a pen drive in the USB2.0 port it loads as USB 2.0 CRW in the ioreg. May be the card reader is not able to load the correct drivers but I don't know how to do it
erroruser Posted December 30, 2018 Posted December 30, 2018 you do not have the usbinjextall kext in the other folder or you never set you kexts to patch in clover i would suggest you go to insanleymac to read the guide of fbpatcher or the other link i post https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v168/ AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
foliasis Posted December 31, 2018 Author Posted December 31, 2018 you do not have the usbinjextall kext in the other folder or you never set you kexts to patch in clover i would suggest you go to insanleymac to read the guide of fbpatcher or the other link i post https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v168/ I did that but still the same
erroruser Posted December 31, 2018 Posted December 31, 2018 [ref]foliasis[/ref], then by unfortunate circumstances you have the rare unsupported sd card reader AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
Naveen Prashanth Posted August 3, 2021 Posted August 3, 2021 On 12/31/2018 at 12:20 AM, foliasis said: but it doesn't mount it shows without any change in kexts also If I use AnyCardReader.kext it is identified as Apple Internal Card but does not mount on inserting the sd card Added in 7 minutes 51 seconds: Another thing that i have observed is that of I plug in a pen drive in the USB2.0 port it loads as USB 2.0 CRW in the ioreg. May be the card reader is not able to load the correct drivers but I don't know how to do it Did it work for you? Can you please share me your AnyCardReader.kext?
