Please help Asus X541U - Mojave Install, Wifi & Sound Not working
[ref]contactwajeeh[/ref], DSDT.aml.zip
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
Hello Maldon,
Appreciate your swift response. I tried with your DSDT and suggested patches, it didnt helped in enabling sound, nor wifi. However I got the battery icon to show but its not showing the current status of the battery like always on 0%. Please find attached the dump after applying your suggestions above.
Thanks in advance.
Send me Mohammeds-MacBook-Pro.zip
[ref]contactwajeeh[/ref], try for audio
check procedure here
u need check what wifi card u have
Is battery status solved?
Donate
Gitter Chat
MSI B360 Gaming Arctic
Hello Maldon,
After spending time reading a lot, I was able to get the install working now the following things work out of the box on a fresh install.
1. Graphics fixed (by using your folder)
2. Audio fixed (by injecting layout 22)
3. lan / ethernet works
The following things are broken
1. Wifi (most probably an unsupported wifi module - RTL8723BE) - Do I have an option to opt for the external usb wifi dongle here?
2. Battery Status - The icon shows as 0% always and as soon as I unplug, I get the batter low message "Your mac will sleep soon...."
3. The trackpad isn't detected, in settings its show no trackpad
Can you please help me on these, I am attaching the files from the runme app for your kind perusal. Looking forward to hear from you soon.
Awesome. it fixed
1. battery percentage
2. screen brightness (which I didn't checked earlier wasn't working for me).
3. Touchpad detected (not all gestures are working but its fine atleast its working)
but after using this DSDT it's working absolutely fine. Anything else I should be looking for? Please advise and thanks so much for your time.
A small gift for you Confirmation number: 1EB35183HG398625H.
[ref]contactwajeeh[/ref], extract new send_me, we need check
[ref]contactwajeeh[/ref], u need a extra procedure i2c
check tread about it in Olarila
Hello Maldon,
I was planning to upgrade the RAM on this build, can I do it safely and also will it reap me any benefits performance wise. Please let me know.
Regards,
Mohammed Wajee
[ref]contactwajeeh[/ref], yes, just upgrade
Hello Maldon,
One more request, I decided to update my laptop to Catalina.
Everything worked fine, but I got a kernel panic when I used the Voodooi2C & Voodooi2CHID kexts, if I remove them from the clover folder it works fine but no trackpad. I am here with attaching the output from runme app can you please look in to it.
Send me Wajees-MacBook-Pro.zip
[ref]contactwajeeh[/ref], looks good
[ref]khalidthami[/ref], try other layout-id
[ref]khalidthami[/ref], use voodoohda
