Mojave + Nvidia? No problem! No Need Web Drivers! Easy Enable Full Graphics Card Acceleration!
I have GTX 780 and i figured how to enable Full Graphics Card Acceleration on my hack! FINALLY!!!!
You need latest kext for GPU: Lilu.kext + WhateverGreen.kext on your EFI/CLOVER/kexts/Other folder.
Bios settings: Internal Grapics: Enable, Internal Grapics Memory Size: 64M
App for test: MacX Video Converter Pro.
76680214_hardwareencoding1.png.3d317b5bda3bae7f5481c5365b612272.png136958145_hardwareencoding2.png.0c8055a99a9e93bb753b897b35f12682.png
Reboot and voila!
You can test your GPU with MacX Video Converter Pro.
You can run Unigine Heaven Benchmark! BOOM!!!!
Hello, I have NVIDIA GeForce GTX 970 4095 MB and with your solution it does not work ... I only get the resolution of the screen very low .. what can it be? Thank you
as far as i know the only nvida cards that work are either Fermi and Kepler cards with out web drivers
:superman:superman
