Hello,
I update my clover bootloader today ..
Now i have a problem with shutdown / restart Mojave freeze at that point..? :wallbash
can you help me..?
Grtz,
Davke
post ur files
RunMe.app
[ref]Davke[/ref], :poke
[ref]Davke[/ref], CLOVER.zip
[ref]Davke[/ref], :guitar:cap
[ref]oldfatandgifted[/ref], try without genericxhci
I thought I tested reboot with it in, but apparently not. Removing it fixed the boot behaviour. As a result, I found an older PCIe USB card I had (bought from China for $15 at the time). To my surprise it seems to work perfectly. I have no way to check throughput speed on the ports, but I suspect they are running properly. I attached a screen shot of what displays in system info. Does this look like native support or just via USBinject? The chipset is listed as via for the 2.0 Hub under that same bus, so I am confused.
*Please see attached.
John
1687576967_ScreenShot2018-11-11at12_27_40AM.thumb.png.fec7ca6136c2d522205fe1dc277de438.png
[ref]oldfatandgifted[/ref], apperas with 5gbs, USB3 bus
Just cloned it before I break it. Very stable as is. Thanks for your help!
[quote name='MaLd0n post_id=66123 time=1541938635
user_id=54]
[ref]oldfatandgifted[/ref]' date=' apperas with 5gbs, USB3 bus
[/quote']
[ref]troubleshooter[/ref], is common in new chipsets, need a full dsdt patched for native solution
[ref]Sychea[/ref], Arquivo Comprimido.zip
use correct folder for serie 100/200/300
https://Olarila.com/forum/viewtopic.php?f=28&t=8222
put ur gpu in first slot x16
[ref]stefanr[/ref], DSDT.aml.zip
use correct folder for ur notebook
hi, i have a problem with the sound, when i upgrade to the last clover i have no sound anymore ,what am i doing wrong?
