Hello everyone, (and apologizes for my bad English)
Recently, on a previous PC, the Mr. MaLd0N helped me get an audio output from the front panel of the PC ... I would like to know what I should configure, or if someone can help me get an audio output from the panel frontal . I made a dump with Run.app, attachments.
I also have a little doubt ... as I said a while ago, I've been in the hackintosh world for a short time, and I wanted to know what the file called NVRAM is created in the root of the EFI partition, I read in the forums of Apple that saves the configuration of the Mac there ... but I do not know if we are talking about the same file. Is essential? What happens if it is removed? What does it work for?
Thanks in advance.
Send me iMac 17,1.zip
NVRAM is a type of RAM that retains data after the host device’s power is turned off. ( in contrast to RAM ). NVRAM is used to store values like: brightness, volume, computer name, Find My Mac’s ID, etc… In Windows and Linux these values aren’t stored in NVRAM but on the HDD, as most PCs don’t have NVRAM. OS X utilizes NVRAM to run many services like iMessage, FaceTime, boot device, etc…
Thanks & Regards
Thank you very much, mr. Allan. :)
So the best I can do is ignore it? Is it modified in some specific case or is it normally ignored?
I also wanted to apologize because lately I've posted a lot, and maybe that can be a nuisance, I do not know. :oops: Anyway, thank you very much for all the help you always offer on this page, I will not tire of thanking you, they have helped me a thousand times more on this page than in many others. Long live Olarila! :D:P
By the way, I just realized that I posted on the forums in Portuguese ... I apologize and would like someone to change this post to the forums in English, if you can not, delete it and recreate it in the forums in English.
Yes. If you don't have issues, don't delete it.
Nah, don't work. That's the main of the Forum ?
You can keep the conversation here. Or we need wait for a Mod (MaLd0n, Mirone or Artur-pt) to do that ?
Thanks & Regards
Nice! :D
Ok, I understand, thank you very much, Allan.
