11 hours ago, danielpl said:
And do you know who can i solve it?
Archive.zip
Hello Maldon
question: for the preparation of the usb for Big Sur something special to add using Clover
Edited by iFabio
need use new clover integration
https://www.olarila.com/topic/10934-guide-new-clover-bootloader-integration-quirks-configuration/
Hello Maldon
I use Clover 5126 with the latest news
Big Sur installation from usb, theme screen I click Preboot the installation starts (boot -v) after the various writings load the apple and I have a restart
advice
with quirks dont have generic way
u need configure quirk for ur hardware
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
Hello Maldon
tried using your efi folder same problem bad loading and rebooting
use of smbios 15.1
the latest version of Clover 5126 with Catalina no problem
Question: Something has changed in Big Sur that needs to be set, for example bios etc.
thanks
Edited by iFabio
reboot where
post one video with this problem
3 minutes ago, MaLd0n said:
reboot where
Big Sur installation from usb, theme screen I click Preboot the installation starts (boot -v) after the various writings load the apple, I have a restart
I can't take the picture, fast reboot
advice
u need use preboot only after kp. after 3 reboot
therefore the installation from usb must be started from boot and not from preboot
Installation of Big Sur from usb, theme screen starts the installation in verbose mode, after the various writings load the apple, I have a restart
these are the photos, before the reboot
https://easyupload.io/iljhcd
Edited by iFabio
use Olarila image
Hi MaLd0n,
I need exact Clover EFI bootloader with injected working kexts of macOS Monterey for my PC. Everything should work. My PC specs are:-
Motherboard :   Gigabyte GA-H81M-S2PV (rev. 2.0)
Processor :   Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz   3.10 GHz
IGPU :  Intel HD 4600  (I don't have any dedicated GPU)
Audio :  Realtek ALC887 codec
LAN :  Realtek GbE LAN chip (10/100/1000 Mbit)
BIOS version FC
Installed RAM :   8.00 GB (7.90 GB usable)
System type :   64-bit operating system, x64-based processor
I really need e complete Clover EFI bootloader for macOS Monterey. Please, can you or anyone give me? ??
Edited by Tahsin Faiyaz Sayor
I added some Info.
5 hours ago, Tahsin Faiyaz Sayor said:
Hi MaLd0n
ur hardware is some old to montery, but work with some tricks. u need fight this war
Please MaLd0n, can you prepare my requested files? I really need them. I can't get it worked. Sound and GPU isn't working on Monterey. I just need a compatible ,complete and working EFI bootloader to make Monterey work fine. Please, I am requesting, can you give me the EFI? Please? ?
start here
https://www.olarila.com/topic/15040-opencore-vanilla-guide-2021-folder-for-chipsets-monterey-ready-desktop-and-notebook/
  • Sad 1
16 hours ago, Tahsin Faiyaz Sayor said:
How can I make the EFI in Windows 10 or 11? Cause I don't have macOS.
burn olarila image and check here
https://tinyurl.com/3w3gclql
