[ref]pangu74[/ref], :guitar
MaLdOn,
i used the Olarila image for mojave but after clover some scripts/text are running on my screen which tells Unsupported cpu
Unsupportes pch but after that it enters installation fine after reboot for installation it tells installation failed error occured
my processor is core 2 quad 9550
cpu dell vostro 230
6gb ram
1 tb hardisk
[ref]abivishvas[/ref], ur processor dont wor in Mojave, native no, u need mod some files
check here
http://dosdude1.com/software.html
Hi MaLd0n
I see there are couple fix in the Acpi/Fixes. Do I need all that? or it depends on what I need?
I also see Boot has -No_Compat_check, but my old one has shikigva=60, do i still need it?
or I can just replace entire confit.plist?
[ref]zoe934[/ref], post ur clover folder here
[ref]zoe934[/ref], looks good
[ref]zoe934[/ref],
update what?
[ref]zoe934[/ref], CLOVER.zip
[ref]zoe934[/ref], :guitar
[ref]khicon9[/ref], use bootkey for boot
[ref]khicon9[/ref], AHCI is enable?
is a nvme?
khicon9, AHCI is enable?
is a nvme?
No, I using SATA 3.
I Use AHCIPortInjector.kext and complete install mojavic on my desktop. But I can't use DVD player and Preview :wallbash
Hello MadLon,
I've made it, thx to you :)
No success with High Sierra I decided to install Mojave (enable ELPM IO Error AppleAHCIPort) and ... voilà :)
There-is the runme zip, if you can give me some new advice I'll appreciate !
Muito obrigado !
MacBook-Pro.zip
Hi Madleon
I tried but I am stuck just after I select to boot from OS X Install High Sierra
I attached what i see in the screen
Can you help me?
[ref]khicon9[/ref], post files here
RunMe.app
Added in 10 minutes 28 seconds:
[ref]farniera[/ref], DSDT.aml.zip
Added in 22 seconds:
[ref]losi[/ref], sound like a corrupted files
Thanks Madleon, I will try to create a new bootabe usb stick and I will be back later!
Added in 37 minutes 36 seconds:
losi, sound like a corrupted files
Hi, I tried to create a bootable usb again but did not work, still stuck in the same place,
I download the image called Download 10.13.6 is it the correct one for my set up? (I don't know if I need to choose another one (like Download 10.13.2 HFS or APFS Download 10.13.6 17G2208 8th Intel Processors).
Is it possible that I did not set something correct in the bios?
But my bios is different from your in the video tutorial
Marco
