@ MaLd0n, Sleep half works for both my X58 and Z77X builds.It worked previously before I used the DSDT's you did for me over at IM, other than that I was on different OS's at the time so should I send the sendme the files for Both?
Tried the Apple menu/sleep as well as auto but same issue happens that within 30seconds all fans etc stops, must press the power button to wake and then nothing on the Monitor so must reset from case but sometimes it seems it triggers a cmos reset then the board reboots and applies the profile before I guess.Bless
danielhutapea,
(49.9 KiB) Downloaded 1 time
Sorry, i'm new. What should I do with this file?
the one that i'm missing is the MaLd0n SERIE 10,20,30.txt file (just following the video)
Thanks a lot.
Added in 2 minutes 14 seconds:
Thanks a lot.
Ups, sorry I found it. I just need to continue watching.
Cheers.
Added in 21 minutes 12 seconds:
Cheers.
I finished everything, but still cannot get audio and wlan working.
What should I do?
Hi [ref]MaLd0n[/ref],
Made a fresh install from my notebook, Sierra to Mojave, just notice some function doesn't work anymore. Have HDMI have video output but no audio, only internal speaker. Please help me once again. Also brightness keys mot working anymore, but perfectly working from Sierra. Attached my sendmefiles. Thanks in advance.
Link to file https://www4.zippyshare.com/v/sUU84yw1/file.html
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
[ref]danielhutapea[/ref], u need check correct model wlan and audio codec
Added in 3 minutes 19 seconds:
[ref]kar2wlan[/ref], DSDT.aml.zip
Added in 2 minutes 29 seconds:
[ref]rositaott[/ref],check new injector for brightness in rehabman site
[ref]kar2wlan[/ref], clover/acpi/patched
hoangmytr wrote: ↑
After removing those FakePCIID kexts, when I plug my USB 3.0 devices in, they're recognized under USB 2.0 with 480mb/s of speed.
MaLd0n wrote: ↑
my patch video is just a name _sun, just check clover info xD
OK
if don't work good, back kexts
After using my hackintosh for a while, I want to come back to report that your DSDT works great with my hack.
:D:D:guitar:guitar:guitar
Thanks so much!!!!!
[ref]hoangmytr[/ref], :guitar
[ref]MaLd0n[/ref], I want to make a fresh install for my notebook (specs on my signature) cause I've messed up my system again trying to figure out the hdmi audio and brightness keys after installing mojave. Which clover should I use from these 2 links;
http://Olarila.com/forum/viewtopic.php?f=28&t=6257
http://Olarila.com/forum/viewtopic.php?f=28&t=6255
Thanks 8-)
time
working thnx man also my brightness keys are f2&f3 they ate not working with slider any way to make them working also my battey not detected using acpi battey manager.
also power management issue
WLAN check here if work
https://bitbucket.org/RehabMan/os-x-fake-pci-id
AUDIO
Added in 3 minutes 23 seconds:
[ref]chuongga2vn[/ref], DSDT.aml.zip
Added in 58 seconds:
[ref]rositaott[/ref], i don't remember, test both xD
Added in 23 seconds:
[ref]bibinalappatt[/ref], Battery check Rehabman repo
plugin type
