send me ur clover folder, DSDT and one ioreg
I'm not sure if there is anything in the archive "CLOVER" that you need .. If not, please write me what is missing and where to find it .. Thank you
CLOVER.zip
My macOS Sierra is barely working. I had audio but I can barely hear anything. My graphics is okay but it's a bit dark and brightness control is not working.
MODEL: HP Envy TS m6
CPU: Intel Core i5 4200U
RAM: 8gb DDR3 1600
GPU: Intel HD4400
HDD: 1TB SATA
SendMe zip file: Send me Rons-MacBook-Pro.zip
replace full clover folder, reboot
CLOVER.zip
CLOVER.zip
(1.75 MiB) Downloaded 1 time
I'm sorry, but it's not going to start ... There's only a black screen with a scroll wheel.
remove ig-platform-id, pressO key in clover boot screen, go to graphics and remove
Excuse me Mald0n, I want to share my problem.
After I updated to 10.13.6, the brightness control couldn't work anymore. I also notice it took longer to boot than before (error/failed showed in verbose mode). And also the usb 3.0 port show needs power. Could you help me, please? I attach files from RunMe.app in Mega https://mega.nz/#!lgtWGawQ!17haa70nGPXUAjyUC-WZ4yOHFxEPg6cWjVpgTPq0pjY
Thank you
Edited:
When I turned on my laptop this afternoon, the brightness now works. The usb 3.0 port seems working either. :D
After I updated to 10.13.6, the brightness control couldn't work anymore. I also notice it took longer to boot than before (error/failed showed in verbose mode). And also the usb 3.0 port show needs power. Could you help me, please? I attach files from RunMe.app in Mega https://mega.nz/#!lgtWGawQ!17haa70nGPXU ... VpgTPq0pjY
Thank you
Edited:
use brightness kext in L/E
Oi!
Instalei o High Sierra de vocês e consegui fazer algumas coisas funcionarem, mas acho que fiz uma bagunça e falta muita coisa ainda. Tem como você dar uma ajuda, por favor?
tem algo errado aí
vc descompactou a imagem? gravou como?
Descompactei com 7Zip e gravei com win32diskimager
eu uso o winrar e nunca tive problemas
(28.49 KiB) Downloaded 1 time
Muito obrigado!
Eu percebi duas coisas:
1. Minha config diz que estou utilizando um iMac, porém na verdade estou no notebook. Isso pode vir a gerar algum problema?
2. Mesmo após a utilização da DSDT eu ainda não consigo usar a GTX 970M. Eu ativo o Web Driver normal e consigo bootar, porém diz que ela não existe! Não está nem na lista de componentes PCI. Você sabe o que poderia ser?
se for optimus, tem de usar a intel HD, eu desabilitei a sua NVIDIA
me envia um novo SEND_ME
testa aí
CLOVER.zip
é notebook ou all-in-one?
testa aí
CLOVER.zip
(1.34 MiB) Not downloaded yet
É um notebook. MSI GS60 Ghost Pro-606 2QE.
Eu testei e as portas USB dão aviso de energia agora, mas Moise e teclado funcionam.
Blz, a gente resolve isso, testa o brightness slider
Valeu!
Consegui mudar a brightness apenas pelo General Settings, mas as hotkeys não fucionaram. Pior que eu não achei mais informações de componentes pra dar um help, só que o touchoad é ELAN e o teclado Steelseries. :(
Valeu!
pro problema do usb tenta com essa versão
USBInjectAll.kext.zip
ro brightness pelas teclas vai ter de usar debug e depois aplicar o patch
Sem sucesso. Tentei colocar o kext que estava antes também e nada. Tentei na S/L/E e no CLOVER, as duas versões
