liemhatang Posted July 2, 2018 Posted July 2, 2018 My System CPU: i3-2100 Main: Asus H61 VGA: Quado K620 what hardware? my hardware. i use ssd samsung evo 850
Administrators MaLd0n Posted July 2, 2018 Author Administrators Posted July 2, 2018 use it and check if appears log after new crash -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
liemhatang Posted July 3, 2018 Posted July 3, 2018 My clover. don't every change. just install nVidia Driver CLOVER Post Install (1).zip
Administrators MaLd0n Posted July 3, 2018 Author Administrators Posted July 3, 2018 My clover. don't every change. just install nVidia Driver run our app RunMe.app app generate all logs -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
liemhatang Posted July 4, 2018 Posted July 4, 2018 run our app RunMe.app app generate all logs I can not run it because when I boot into the main screen, about 10 to 15 seconds is my computer has been standing, CPU is not working, mouse, keyboard ....
sagerian Posted July 8, 2018 Posted July 8, 2018 Audio and sleep problem here. Using macOS High Sierra 10.13.1, with model identifier iMac12,2. I managed to install video, LAN, audio with AppleALC.kext, PS2 and USB drivers and besides sleep, everything worked fine. Then, I left my computer unattended and it went to sleep. Funny, since if I try to put it to sleep with mac menu - Sleep, it doesn't shut down, only the monitor goes to sleep. When I tried to wake it up, it kept coming out of sleep and going back. Even the reset switch was useless. I had to shut it down completely and start it up again to properly boot. Since then, audio is dead, even if I redownloaded and replaced Lilu.kext 1.2.3. AppleALC.kext and VoodooHDA.kext are both useless. In Windows and Linux, audio works fine, as before. All my kexts are in EFI partition, in /EFI/CLOVER/kexts/Other. I have no idea how to fix sound or sleep problems. Update: Sound is working now. After more reading about kexts, I downgraded Lilu.kext from version 1.2.3 to 1.0.0 in EFI partition, /EFI/CLOVER/kexts/Other. Though I don't understand this, because it worked fine with version 1.2.3 for a day or so. Send me admins-iMac.zip MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 8, 2018 Author Administrators Posted July 8, 2018 Audio and sleep problem here. Using macOS High Sierra 10.13.1, with model identifier iMac12,2. I managed to install video, LAN, audio with AppleALC.kext, PS2 and USB drivers and besides sleep, everything worked fine. Then, I left my computer unattended and it went to sleep. Funny, since if I try to put it to sleep with mac menu - Sleep, it doesn't shut down, only the monitor goes to sleep. When I tried to wake it up, it kept coming out of sleep and going back. Even the reset switch was useless. I had to shut it down completely and start it up again to properly boot. Since then, audio is dead, even if I redownloaded and replaced Lilu.kext 1.2.3. AppleALC.kext and VoodooHDA.kext are both useless. In Windows and Linux, audio works fine, as before. All my kexts are in EFI partition, in /EFI/CLOVER/kexts/Other. I have no idea how to fix sound or sleep problems. Update: Sound is working now. After more reading about kexts, I downgraded Lilu.kext from version 1.2.3 to 1.0.0 in EFI partition, /EFI/CLOVER/kexts/Other. Though I don't understand this, because it worked fine with version 1.2.3 for a day or so. CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sagerian Posted July 8, 2018 Posted July 8, 2018 MaLd0n, should I replace my Clover folder with the one provided by you in the archive? Will this config work if I upgrade to a newer version, like 10.13.5? MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 8, 2018 Author Administrators Posted July 8, 2018 MaLd0n, should I replace my Clover folder with the one provided by you in the archive? Will this config work if I upgrade to a newer version, like 10.13.5? yes take a shot -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sagerian Posted July 8, 2018 Posted July 8, 2018 I just tried your Clover folder. Audio: works. LAN: does not work. Sleep: works Wake up from sleep: is horribly wrong. I have noticed IntelGraphicsFixup.kext in there. I don't have an Intel graphics card. Does it have any other meaning? MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 8, 2018 Author Administrators Posted July 8, 2018 I just tried your Clover folder. Audio: works. LAN: does not work. Sleep: works Wake up from sleep: is horribly wrong. I have noticed IntelGraphicsFixup.kext in there. I don't have an Intel graphics card. Does it have any other meaning? MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover run .app again and post new files -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sagerian Posted July 9, 2018 Posted July 9, 2018 These are the files generated by RunMe, with the CLOVER folder exactly as you uploaded it. The only modification I did to the system was to install Nvidia Web Driver. But it does not load, macOS still uses OSX Default Graphics Driver. Send me admins-iMac.zip MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 9, 2018 Author Administrators Posted July 9, 2018 These are the files generated by RunMe, with the CLOVER folder exactly as you uploaded it. The only modification I did to the system was to install Nvidia Web Driver. But it does not load, macOS still uses OSX Default Graphics Driver. Attachments Send me admins-iMac.zip with my files -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sagerian Posted July 9, 2018 Posted July 9, 2018 Yes, with your CLOVER folder. I copied it in EFI partition, then I installed Nvidia Web Driver. MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 9, 2018 Author Administrators Posted July 9, 2018 http://Olarila.com/forum/download/file.php?id=9734 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sagerian Posted July 9, 2018 Posted July 9, 2018 With this new CLOVER folder, macOS doesn't boot anymore. I managed to take a picture of the screen with my phone: https://ibb.co/hAHLU8 MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 9, 2018 Author Administrators Posted July 9, 2018 uncheck drop OEM -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sagerian Posted July 9, 2018 Posted July 9, 2018 I unckecked "Drom OEM" in Clover Configurator, exported the configuration and it's getting better: Audio: works LAN: works PS2 keyboard: does not work. But strangely enough, pressing a key while computer is sleeping, wakes it up Sleep: works, the video card, the fans, the PSU, all seem to stop Wake up from sleep: does not work. The video card does not wake up the monitor, a red LED is blinking on the motherboard. When the computer is running normally, that LED is off. Send me admins-iMac.zip MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 9, 2018 Author Administrators Posted July 9, 2018 I unckecked "Drom OEM" in Clover Configurator, exported the configuration and it's getting better: Audio: works LAN: works PS2 keyboard: does not work. But strangely enough, pressing a key while computer is sleeping, wakes it up Sleep: works, the video card, the fans, the PSU, all seem to stop Wake up from sleep: does not work. The video card does not wake up the monitor, a red LED is blinking on the motherboard. When the computer is running normally, that LED is off. if don't work, live with it CLOVER.zip u have a good system, just sleep don't work, it's common in many mobos series 6, x79 too -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Aidzi Posted July 10, 2018 Posted July 10, 2018 Hi, I wrote already on FB .. Can anyone help config.plist change my hw - in the description? I have to start the video card and audio .. the file i attached .. i tried the above changes and settings but without success .. thanks for your help. The config.plist file will be sent to PM. Mainboard: GA-B150M-DS3H DDR3 PROCESSOR: Intel i5-6500 3.19GHz Graphics: INTEL HD 530 config.plist.zip
sagerian Posted July 10, 2018 Posted July 10, 2018 MaLd0n, I'll leave it like it is now. Thank you for your help. MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover
Administrators MaLd0n Posted July 10, 2018 Author Administrators Posted July 10, 2018 Hi, I wrote already on FB .. Can anyone help config.plist change my hw - in the description? I have to start the video card and audio .. the file i attached .. i tried the above changes and settings but without success .. thanks for your help. The config.plist file will be sent to PM. Mainboard: GA-B150M-DS3H DDR3 PROCESSOR: Intel i5-6500 3.19GHz Graphics: INTEL HD 530 i need a full dump -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted July 10, 2018 Author Administrators Posted July 10, 2018 MaLd0n, I'll leave it like it is now. Thank you for your help. MB: Asus P8P67 rev3.1 CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz) RAM: 16 GB DDR3 Corsair VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory HDD 250GB (macOS 10.13.1), GPT, Clover k enjoy -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Aidzi Posted July 10, 2018 Posted July 10, 2018 MaLd0n - Can you tell me what exactly am I going to do, please?
Administrators MaLd0n Posted July 10, 2018 Author Administrators Posted July 10, 2018 MaLd0n - Can you tell me what exactly am I going to do, please? send me ur clover folder, DSDT and one ioreg -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
