1 hour ago, jhonwick said:
my desktop reset to default wallpaper and opened program also remove from dock when i reboot. Also the countdown not working in clover bootscreen.
Maybe I'm wrong, but I think that is a NVRAM issue… probably your mobo don't have native nvram.
Put EMUVariableUEFI.efi at Clover UEFI drivers - this will solve many issues.
But with olarila's EFI folder at least countdown will work.
iMac 19,2 (10.15.4) + Win 10 @ OpenCore UEFI Dual Boot
H310M-S2P | i3 8100 | 16GB DDR4 | UHD 630 + RX 580 (PowerColor) | ALC887 | Realtek RTL8118 | TP-Link WN781ND
yes. i think so thats a NVRam issue. but i cant fix that till now. tried EMUVariableUEFI.efi with that but no luck. I just lost my previous efi parition, otherwise previous my hackintosh was perfect. But after formatting im facing such issues and cant fix. Trying from 4days+
Finally the countdown in clover working (Paste the clover folder from Olarilla installer) and now my olarila HS booting successfully with audio working. But the only issue still existing that NVRam issues that opened program remove from dock i mean its quite when i restart. Please help
well, I think that this problem is not related at all to nvram, but to solve nvram problem you'll need install also Clover's RC scripts.
I did but no luck... still trying and googling to fix until i get response from Olarila
Ola! Meu primeiro post aqui. Instalei o Catalina no meu pc e o único problema dele esta com o video... esta com o hz baixo e não consigo mudar. Meu setup e intel 7700k gigabyte gtx1070 e 16gb eram ddr4. Sei que a placa de video eh incompatível mas gostaria de saber se teria como resolver o erro do hz sem ter que mudar pra intel hd graphics pq estou com dificuldades de configurar para a intel. Outra solução que pensei seria voltar para o High Sierra mas aparentemente os links de download não estão funcionando.
se puder ajudar fico agradecido, obrigado!
google drive tem limite diário de download, use os torrents
no catalina precisa desativar a nvidia e usar somente a intelhd
Ok! Gostaria de saber como faço pra desativar. a gtx e usar somente a intel 630 de forma corretamente pq do jeito que eu havia feito o pc liga mas fica com uma cor estranha e muito lento,
obrigado
via dsdt, ssdt ou pelo próprio bootloader
1 minute ago, vinpo said:
My hardware is: Asus Z170A, i7 6700K, RX 580 N+ 8GB, 32 GB DDR4
updated kexts and bootloader? oc quirks last version is not good
@MaLd0n Hello,
Could you please help me. I cant figure it out whats exactly happening. I've tried and follow many topics from Olarila and comments but still stuck with the issue that i still cant fix. The issue is my Olarila HS booting successfully but one thing is that i think NVRam is not working this time as my opened program remove from dock when i reboot. I mean not getting back the stats after reboot. Also i need to force reboot two times using powerbutton to get to the desktop, the first time its stuck middle of the boot. Its random. Sometimes its boot successfully in one attempt.
Here is http://s000.tinyupload.com/index.php?file_id=02942576455798961576
Please take a look.
Regards
49 minutes ago, jhonwick said:
@MaLd0n Hello
install clover with rc scripts for emulate nvram, if need use emuvariable
Already updated kext and Clover
Hi ,
My PC configuration is
Processor: i5 9400F
Motherboard: MSI B360M Pro-VH with Intel B360 Chipset
Graphics Card: Nvidia 1050 - TI OC edition
I tried with latest Olarila High Sierra image and it didn't work.
Is there any possibilities to get Hackintosh work on my setup?
yes
good hardware
post one photo in error screen
6 hours ago, rositaott said:
Notebook Dell Inspiron 5593 i5-1035G1 8GB 512SSD 15.6" MX230 2GB
black screen after verbose?
