Hi I have Tahoe on one drive ,Sequoia on the other as a main os.
How can I fix Tahoe's audio problem without messing up Sequoia?
They both use the same EFI.
Which audio fix is better in this situation?
Thks
set max kernel to applealc 24.9.9
  • Thanks 1
