webcam problem
Hello. I have asus n53 sn laptop and lion 10.7.1 retail. I have problem with my webcam. It doesn't work with facetime and photo booth. But it works other non apple apps such as flash player. Can you help me please?
OS X Lion 10.7.2
Asus N53SN-SZ007
Intel Core i5 2410M 2.3 gHz CPU with Intel HD300 Graphics
Nvidia Geforce GT550M 2gb GPU
4 gb ddr3 Ram
500 gb 5400rpm HDD
Atheros AR9285 wifi
Realtek alc269 audio
What's the camera resolution? May be the same situation as here
http://netkas.org/?p=909
If it's not resolution related, maybe this helps
http://www.insanelymac.com/forum/index.php?showtopic=238847
Tried, but none of them worked. Thanks anyway bro.
OS X Lion 10.7.2
Asus N53SN-SZ007
4 gb ddr3 Ram
500 gb 5400rpm HDD
Atheros AR9285 wifi
Did you edit Info.plist properly with device and vendor ID of your camera?
Yes I did. And now it shows my webcam as iSight cam. But it doesn't work either. Can it be related IOPCIFamily kext? Because i use modified one.
OS X Lion 10.7.2
Asus N53SN-SZ007
4 gb ddr3 Ram
500 gb 5400rpm HDD
Atheros AR9285 wifi
hi there,
how to check dev id for integrated webcam.
any help is really appreciated. TQ
Dell Latitude 6320
Processor: intel core i5 2520M CPU@2.5 Ghz
GPU: Intel HD Graphics 3000
MAC OS X 10.8.2
cr3dit to:
cassio
oldnapalm
artur-pt
there are heroes!
oldnapalm
thanks for the advice.
i have searched dev id and vendor id under system profiler > USB
but non is found.
see picture.
some info for USB
Asus > wireless USB
8550 > broadcom bluetooth
appreciate your advice. TQ
Dell Latitude 6320
MAC OS X 10.8.2
cr3dit to:
cassio
oldnapalm
artur-pt
there are heroes!
