Easy audio solution on Hackintosh on macOS Tahoe
14 hours ago, MaLd0n said:
yep, the system does not ask for permissions when copying a kext
when opening the installation software, it prompts, but not during installation.
the result of the kext is not loaded by the system
sudo kmutil load -p /Library/Extensions/VoodooHDA.kext
Password:
Authenticating extension failed: Kext org.voodoo.driver.VoodooHDA v3.3.4 in executable kext bundle org.voodoo.driver.VoodooHDA at /private/var/db/KernelExtensionManagement/Staging/org.voodoo.driver.VoodooHDA.JYwVNJ/VoodooHDA.kext:
Authenticating extension failed: Bad code signature
Edited by Дмитрий Беженцев
Strange. I'm using this kext everyday in some hacks and no problem at all. Use sip 03080000 and try.
such a sip was issued I deleted RestrictEvents today.kext thought maybe it was interfering, but the behavior has not changed, the system does not respond to copying VoodooHDA.kext
I can't imagine what might be interfering with my work. I've run out of ideas.
