DSDT help - Victus Gaming Laptop - Ryzen 5600H with Radeon Graphics
Hi, I have successfully booted into the software and it is booting within seconds, but there are some features not working. I have attached the necessary send me files that you have requested. Please help me out thanks
I was not able to attach the kexts folder into the forum so I will list all the kexts currently running on my system
  • Lilu
  • Virtual SMC
  • Apple ALC
  • AMDTSCsync
  • NootedRed
  • AppleMCEReporterDisabler
  • VoodooPS2Controller
  • RestrictEvents
  • USBToolBox
  • UTBMap
  • RealtekRTL8111
  • SMCBatteryManager
  • AMDRyzenCPUPowerManagement
  • SMCAMDProcessor
  • BrightnessKeys
Send me Anishs-MacBook-Pro.zip
What things dont work?
I already know that Wifi doesnt work since its not a compatible wifi card. The battery information is not working its not showing up in the settings and the trackpad is completely inresponsive. The other thing that doesnt work is the audio. I already checked it with the list in Apple ALC. its ALC245 and the id is either 11,12 or 13 and I have tried all three and these doesnt work. The only major problem that I want to get solved is that in hackintool the VGA decoder information shows Decoder failed. I need to get there 4 sorted.
Battery , Trackpad, Audio and finally VGA decoding.
Thank you. If you need more information let me know. I'll provide the necessary information. Thanks
Need expert help with your Hackintosh?
Get professional Olarila support for:
Support us - Donate HERE
