artur-pt Posted November 18, 2014 Posted November 18, 2014 hello possible solution use ig-platform-id 0x01660004 and this patch clover good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
mrgtrader Posted November 27, 2014 Posted November 27, 2014 OS is recognizing the Intel HD 4000 card, but everytime it attempts to load the kexts, it fails... I had to remove all the AppleIntelHD* kexts to another folder in order to boot the notebook. But know I dont have video acceleration... It`s a problem with the kexts or I need a DSDT.aml ? MAC OS X Maverick- 10.9.0 Acer Aspire M5 481PT IvyBridge Intel Core i5 3337U - 4GB RAM (1333Mhz) Intel HD Graphics 4000 - RealtekHDAudio ALC269 Atheros Wi-fi - Broadcom Netlink
artur-pt Posted November 27, 2014 Author Posted November 27, 2014 hello are u sure that is ur problem ? u have glitches in ur lcd ? u must use the right ig-platform-id for the hd 4000 usually platform-id 3 .. resolution 1366x768 platform-id 4 .. bigger resolution .. also use dual link http://clover-wiki.zetam.org/Configuration/Graphics#ig-platform-id and use a proper smbios good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
mrgtrader Posted November 27, 2014 Posted November 27, 2014 Ok, thanks for the answer... I am already using platform id 3... But I am using chameleon, not clover... like this: GraphicsEnabler Yes IGPEnabler Yes InjectIntel-ig 03006601 IntelCapriFB 3 IntelAzulFB 3 Graphics Mode 1366x768x32 And this settings works, it shows Intel HD 4000 on System Information app, with another set of keys it doesn`t. And my SMBios I have set according to a post saying that is the best for my processor: SMbiosdate 05/10/12 SMbiosvendor Apple Inc. SMbiosversion MBA51.88Z.00EF.B00.1205221442 SMboardproduct Mac-2E6FAB96566FE58C SMfamily MacBook Air SMmanufacturer Apple Inc. SMproductname MacBookAir5,2 SMserial C02LG674DRVC SMsystemversion 1.0 The problem is that the system doesn`t boot up since installation... only in safe mode OR if I remove the AppleIntelHD* kexts. I have to return this kexts, but how do I do that without ruining my system? I was able to boot the system one time with all the kexts, but that time I have installed a patched AppleIntelCpuPowerManagement... however the system showed me Kernel Panic after a few minutes so I removed it and now I am using NullCpuPowerManagement... it could be it ? In another topic someone suggested to use an DSDT.aml but I have no idea how. MAC OS X Maverick- 10.9.0 Acer Aspire M5 481PT IvyBridge Intel Core i5 3337U - 4GB RAM (1333Mhz) Intel HD Graphics 4000 - RealtekHDAudio ALC269 Atheros Wi-fi - Broadcom Netlink
artur-pt Posted November 27, 2014 Author Posted November 27, 2014 hello azulfb .. is not for the hd 4000 is capri .. u should read more.. about ur graphics.. http://Olarila.com/forum/viewtopic.php?f=28&t=3111 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
mrgtrader Posted November 28, 2014 Posted November 28, 2014 Yes, I have read, but didnt understand completely... and since it worked I didnt remove the AzulFB key. I was reading the topic you mentioned and except for the DSDT patch (which I have no idea how it works), everything is fine. I think gonna try a fresh install and changes some things, see if it works. I`ll be back. MAC OS X Maverick- 10.9.0 Acer Aspire M5 481PT IvyBridge Intel Core i5 3337U - 4GB RAM (1333Mhz) Intel HD Graphics 4000 - RealtekHDAudio ALC269 Atheros Wi-fi - Broadcom Netlink
mrgtrader Posted November 29, 2014 Posted November 29, 2014 Yes, I`m back! I tried almost everything, including DSDT patches... i was already downloading the Yosemite to try it, see if it works when I found this guide: http://rampagedev.wordpress.com/more-guides/intel-hd-graphics-guide/ First I only have tried the 3 and 4 IDs... but after seeing this guide I tried the 1 and it worked! Really AWESOME! I don`t know why, but the first guide I read showed me that the 1 ID was no good for me... for this reason I have even tried. Obs.: And I have changed too my SMBios, according to this new guide. MAC OS X Maverick- 10.9.0 Acer Aspire M5 481PT IvyBridge Intel Core i5 3337U - 4GB RAM (1333Mhz) Intel HD Graphics 4000 - RealtekHDAudio ALC269 Atheros Wi-fi - Broadcom Netlink
