moumouh206 Posted July 8, 2023 Posted July 8, 2023 Howdy, So I've made a hack on an old laptop of mine which works pretty well. All the features that I needed all work except one thing, the audio. I've used OpenCore and I have tried the Post-Install guide on how to fix the audio and had no luck. My Codec Is ALC236 I got it from Aida64 on Windows, which is supported by AppleALC and I have tried every single layout-id both from my specific codec & the whole IDT family, it just doesn't work. Going further down in the guide and checking if AppleALC is patching correctly or not, It's not but the solution to that as the guide says is still to find the right Layout-id and apparently, none of them work for me. I was wondering if anyone could help me figure why this is happening? You can check my screenshots on Hackintool and DPCIManager and Opencore configiurator macOS Version: Monterey 12.6.7 (It was broken in Catalina and Big Sur too). My Laptop Is The: Lenovo Z51-70 Thanks! attachments.zip
Administrators MaLd0n Posted July 9, 2023 Administrators Posted July 9, 2023 if applealc dont work u can create ur layout or try with voodoohda -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
moumouh206 Posted July 9, 2023 Author Posted July 9, 2023 3 hours ago, MaLd0n said: if applealc dont work u can create ur layout or try with voodoohda Thanks for replaying , I have already try voodoohda by placing the kext inside EFI folder and enable it in Opencore but it doesnt work , how do i create my own layout ? can you point me to the right tutorial please ?
Administrators MaLd0n Posted July 10, 2023 Administrators Posted July 10, 2023 https://github.com/acidanthera/AppleALC/wiki 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
