Dyslexity Posted April 19, 2022 Posted April 19, 2022 Hi. Can anyone help me with this? I already installed monterey on my ryzen but when I tried it on my intel, this shows up. Can anyone help me what this means?
Administrators MaLd0n Posted April 19, 2022 Administrators Posted April 19, 2022 Some Basic Information -Use USB2 port for easy installation with no remap USB -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Dyslexity Posted April 19, 2022 Author Posted April 19, 2022 1 hour ago, MaLd0n said: Some Basic Information -Use USB2 port for easy installation with no remap USB -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen Hi. Thank you but I already tried all of those. I guess no mac for my Intel.
Administrators MaLd0n Posted April 19, 2022 Administrators Posted April 19, 2022 what ur hardware 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Dyslexity Posted April 21, 2022 Author Posted April 21, 2022 On 4/20/2022 at 4:55 AM, MaLd0n said: what ur hardware Its a Lenovo V530. i5-8400. Thanks.
Administrators MaLd0n Posted April 21, 2022 Administrators Posted April 21, 2022 is easy folder for coffeelake https://tinyurl.com/hswtduv8 with -igfxvesa for easy installation and iMac19,2 smbios 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Dyslexity Posted April 21, 2022 Author Posted April 21, 2022 11 hours ago, MaLd0n said: is easy folder for coffeelake https://tinyurl.com/hswtduv8 with -igfxvesa for easy installation and iMac19,2 smbios Will you please guide me on how to do the -gfxvesa? I cant seem to find the guide on how to do it. Thank you very much.
Administrators MaLd0n Posted April 21, 2022 Administrators Posted April 21, 2022 https://easyupload.io/lmc1k7 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Dyslexity Posted April 21, 2022 Author Posted April 21, 2022 21 minutes ago, MaLd0n said: https://easyupload.io/lmc1k7 I got access denied.
Administrators MaLd0n Posted April 21, 2022 Administrators Posted April 21, 2022 https://www.transfernow.net/dl/20220421K9dbqwI6 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Dyslexity Posted April 21, 2022 Author Posted April 21, 2022 18 minutes ago, MaLd0n said: https://www.transfernow.net/dl/20220421K9dbqwI6 Will try it. Thank youuu.
Dyslexity Posted April 21, 2022 Author Posted April 21, 2022 (edited) 11 hours ago, MaLd0n said: https://www.transfernow.net/dl/20220421K9dbqwI6 Hi. I tried it and Im still getting the same result. Edit: Sorry, its working now. Thankyouu very much!! Edited April 22, 2022 by Dyslexity
