Hi,
installed Monterey as per olarila guide.
everything is working apart from sound and brightness
I have already tried https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/ but the problem is that I have no audio devices
please see screenshots and attached config.
would appreciate any help
Laptop: Lenovo Thinkpad Yoga 15
CPU: Intel i5 Broadwell 5200U
Graphics: Intel HD 5500
Screenshots.zip config.plist.zip
seems like a irqs problem
u need fix irqs in some devices
this patch is mandatory for all
12 minutes ago, MaLd0n said:
how/where do I remove ssd and add the DSDT you sent?
Never mind i worked it out, audio now appears to be working! Thank you!
Finally, have you got any idea about how to fix brightness slider?
